Ve30de oil leak
Ve30de oil leak
1993 Maxima se has an oil leak I can’t really tell where it’s coming from but it’s dripping right onto the rear exhaust manifold and burning to the point where it’s its filling up the passenger compartment up with smoke and making it hard to breathe. Any ideas? Probably the valve cover gasket
I've only dealt with the valve cover gaskets on the vg but I would imagine you'd only have to remove the upper intake manifold to get at the valve covers on the ve too. If you need to remove any vacume lines just remember where to put em back. It would probably be a good idea to take a couple pics before hand and have an fsm handy which you should be able to get a link for from here on the org.. Looking at your user name did you have a vg and switched over to a ve or something?
Yea I’m only used to vgs never messed with a ve. It’s almost impossible to find parts for this engine. I found the valve cover gasket and intake manifold gasket I need but they’re special order parts which I will have to wait a few days for which I can’t really afford to wait considering I need my car while I’m at work. Nice job Nissan for making an engine for 2 years then stopping
as far as i know its only upper intake to get to the valve covers, its not overly hard. just take pictures with your phone of it all beforehand and make mental note where the electrical connectors and vacuum lines go. rarely will electrical connectors interchange so you cant put them in the wrong spot and vacuum lines are often a different length or size so you cant mess them backwards
It was pretty straight forward the only problem I had was one hose connection broke from the piece it hooks up to which was a easy fix with a longer piece of hose and the egr valve pipe broke in the process which was my dumbass fault for taking it off incorrectly so I had to make a makeshift egr valve block plate and now how have to epoxy the pipe sticking out of the exhaust manifold in order to get rid of this exhaust leak which makes my car sound type ghetto
edwardh1
37
Sep 12, 2015 07:10 PM
soundquest
Jun 11, 2015 06:52 AM
DTrem08
Jun 20, 2010 06:32 AM
reMaxxxK
Oct 3, 2005 06:47 PM
