Driver side window problem
Old Jan 15, 2018 | 12:53 PM
SEMaxima2000's Avatar
What's up Org, I'm having an issue with my front driver side window. At one point I was able to roll it down but it wouldn't come all the way back up, it would stop and then roll back down, sometimes I would be able to help it go all the way up, when I am able to get it all the way back up for a few minutes or hours it won't roll down or anything, the button will not do absolutely anything. I don't have that problem with any of my other windows. I've searched the forums for possible answers but I haven't seen any posts that match my problems. Any help from you all would be appreciated before I take the dreaded drive to the dealership to see what their diagnosis would be.
Old Jan 15, 2018 | 01:35 PM
follyburr's Avatar
I've had similar issues, i think. It was the window motor. Mine was also the front driver window. I would be able to roll down the window with the switch, but couldnt roll it up. I had to do it by hand. Eventually, I couldnt do either so I bought a new aftermarket motor and replaced the old one. It works now. BTW, I bought a cardone select window motor and was on my 3rd one after a year. Good thing Rockauto.com was good on warranty.
Old Jan 15, 2018 | 01:36 PM
Les7311's Avatar
Accentuate is going bad. Once it goes down and doesn’t want to go back up, then that’s it. Early warning.
Old Jan 15, 2018 | 02:43 PM
How difficult was it to replace?
Old Jan 15, 2018 | 02:48 PM
Les7311's Avatar
Here’s your guide
The video is farrrrrrr more difficult that you actual doing he Job yourself
I’ve replace three on different vehicles watching YouTube and all went well.
You can do it!!!!
Old Jan 15, 2018 | 03:58 PM
The circled item is what i need to replace? I'm a noob when it comes to repairing my car, some things I can do but this is a new one for me.
Old Jan 15, 2018 | 04:22 PM
Les7311's Avatar
Once you starT taking off the buttons and bolts, you get into a rhythm. Place all the clips etc on your floor mat.
Out of 10, being the worse, this is a 2.
Yes!
Old Jan 23, 2018 | 11:30 AM
Does anyone know the part number or the specific part I need to look for?
I'm looking on my local Nissan Parts website and I think I found what I'm looking for..
MOTOR ASSY-REGULATOR,LH - 807317Y000 ... Is that correct?
I'm not necessarily going to order it from there just making sure so I can shop around, Thanks in advance.
Old Jan 24, 2018 | 09:19 AM
Doc Plus's Avatar
Before buying and swapping a part, you should be sure.
You can do the tests described page GW-54: http://www.nicoclub.com/FSM/Maxima/2006_Maxima/
kasemodz
Mar 1, 2011 07:57 PM
xmaxima95x
Sep 22, 2009 05:41 AM
SilverSleeper
Mar 13, 2003 09:34 AM
Rookwood
Oct 26, 2000 07:11 PM
