2004 Maxima se ecu and ignition swap but car won't run
Old Jan 28, 2018 | 04:47 PM
Kpowell577's Avatar
I bought an 04 Maxima se for pretty cheap but they couldn't find the key so a friend has had the same car sitting in his backyard for about a year now so I grabbed the ignition and the ecu out of that car and swapped it with the one in my car ( because he had a key to his). Now I know when you get a new ecu u have to have the keys programed by the dealer to the new ecu but I swapped then both together. My car will turn over but will not start almost like the immobilizer turned on. Any thoughts on what it could be?
Old Jan 28, 2018 | 05:23 PM
Osbaldo Rodriguez's Avatar
So you did or didn't have them programmed? I had an issue with the immobilizer, I have same year and trim as yours. I just turn the key on the door over and over always helped me. Of course this isn't a permanent fix.
Old Jan 28, 2018 | 09:28 PM
Kpowell577's Avatar
Do I need to have the ecu reprogrammed if it is the one that went to the ignition and keys I also swapped out the door locks. I forgot to mention. So I swapped out the old ignition ecu and door locks lcoks do they need to be reprogrammed if they all went together I just put then in a new car
Old Jan 29, 2018 | 04:50 AM
Afterlife's Avatar
did you swap BCM also? if not it will need programmed
Old Jan 29, 2018 | 05:58 AM
Kpowell577's Avatar
No I didn't I wasn't aware that it would onset the NATS system. I hooked the code reader up to it last night and it's reading p1615 and p1610
Old Feb 2, 2018 | 05:51 PM
Rianbarber's Avatar
Need help keep getting p1273 and p1283 ses light after swapping my engine out. There's no vaccum leaks change all 4 sensors still getting light
Carlos1
Jan 28, 2018 12:25 PM
jettech
Nov 14, 2004 06:56 AM
ngthing
Mar 20, 2001 08:06 PM
