Maxima - Slip - Brake - ABS- Traction Lights Stay On
Old Apr 8, 2018 | 08:27 PM
Badonkadonk's Avatar
Hey all,
I have a 2006 Nissan Maxima with approximately 125,000 miles on it. Just the other day I was driving and the - Slip - Brake - ABS- Traction Lights came and stayed on. When i restart the car all the lights are off, but when I go about 3-5 miles an hour the lights come back on and stay on till I shut the car off.
Now, I do have a traction control button I can turn off and on. For the heck of it I tried turning it on to activate it with all those lights on and it does nothing at all. It does not even turn the light off and on. Im thinking its because its deactivated when the all the lights are on. I'm not sure if that has anything to do with my lights issue or not, but I wanted to point that out.
so, does anyone know what's causing the, Slip - Brake - ABS- Traction lights to come on?
Thanks,
Badonkadonk
Old Apr 14, 2018 | 08:06 AM
vqmaxman's Avatar
I think you should check and see if it's the brake acuator motor that would cause your light to come on because thry are known fail and to go bad. The other thing you wanna check is the ABS sensors. The ABS sensors may have gonne bad and throwing the ABS light. If the lights off and you start the car up immediately the ABS lights on and blinks once but stays on it's known that the actuator has gonne bad. The nissan scanner will pinpoint this problem accurately. The acuator is the ABS module that's sitting in the back firewall driverside.
Networkable
Apr 8, 2018 06:44 AM
MTR
Oct 1, 2014 09:13 PM
165donaldw
Nov 11, 2012 09:38 AM
max1008
Oct 19, 2012 08:44 AM
