Turn signals don't work unless hazard switch pushed slightly
96 I30
turn signals don't work, but hazard flashers do work.
If I push the hazard switch in slightly, the turn signals will work.
Is this just a bad hazard switch?
Sounds like the hazard switch but could be the flasher relay which is something like $10-12 at an auto store and plugs in under the dash. if it was me I'd try it and return it if that wasn't the case and then try the hazard switch unless you've got access to one you could try
Bad switch.
the one in my 92 Nissan pickup does that too.
I have disassembled switches from other cars.
I cleaned any crud deposits with fine sandpaper, then reassembled. This worked more often than not.
I don't know if it's possible to take our switches apart.
Please check fuse 14 (7.5A) at Fuse J/B if it is not blown.
(Reference diagram 97 FSM page EL-66. Turn signals are powered by fuse #14 when car key is ON or START. When hazard button is pushed in, turn signals are powered by fuse #11)
*************** UPDATE ******************
It was the turn signal fuse! Thank you everybody for your help!
Thanks!
maximaboi
Feb 21, 2015 02:35 AM
playtoy
20
Oct 31, 2012 03:15 PM
blackandwhite
18
Jun 24, 2008 09:07 AM
The New CLIMAX
May 4, 2001 06:36 PM
