1st - Lost an original coil, replaced with a Duralast one from autozone, no problems.
2nd - Lost another original coil and ordered a full set minus one for that which I just replaced.
Installed two of those new coils, one in place of 2nd original that failed, and one on another cylinder where the original still worked. The others were pretty stuck so I just left them since they still work.
3rd - lost one of the new ones from the set, replaced with the original that still worked.
4th - lost a second one of the set I bought, and now have none left working to replace it with.
So this is four failed coils in a few hundred miles.
This set I bought is Hitachi which I have read is good quality, and it seems they are failing more than the Duralast or originals.
The spark plugs are fine. Is this just a bad set of coils or what could be killing them like this? Should I buy another Duralast? A whole set of another brand?
My car is a 97. The plugs came with the car but look good and have correct gap, and correct NGK part. I was thinking if something else that could kill them or I just got a bad Hitachi set?
How many miles have you put on the car since buying it? How many miles do you think are on the plugs?
Those are actually not the OE type. NGK is OEM, but not that particular version. The one you have is single platinum. The OE type is double platinum. NGK Laser Platinum is the name of the OE type. Double platinum lasts longer than single platinum.
Four failed coils within 100 miles on a pre-99 is relatively unheard of.
Have the fuel injectors ever been replaced? Do you have any CEL codes?
I've had the car just over a year and put on 14k miles with no problems.
If I had to guess, the plugs are newish because the car had some other work done shortly before the sale to me as well and maybe did them.
The fuel injectors I can only assume are original, and have never had issues or messed with them.
Well, when this happens I get the flashing CEL for a misfire and get code for misfire on a cylinder, and sometimes an ignition circuit code as well. I don't have a scanner so I'm flashing these out on the CEL to read them.
When I check the coils, the bad one is totally dead at idle and makes no difference unplugging it. If I move it to another cylinder, the problem moves.
Failures are located: 2 on cylinder #2, 1 on cylinder #4 and 1 on cylinder #6
Strangely none on the other bank.
Measuring the good and bad ones with a v/ohm meter, the resistance of the primary and secondary windings are sometimes still pretty close to normal and sometimes way out. It seems pretty random.
I wonder if something electronically upstream has gone off spec. Maybe the voltage spec feeding the coils is off or the wire compromised and can't feed all of them running simultaneously Compromised amps draw.
And then it could be you got a bad batch. It does happen. Hopefully, there's a LLW and you can bring all 6 back and get a fresh batch.
But if you do that and they fall quickly too, look elsewhere.
About 7 or 8 years ago, I bought two from Napa. Never looked back. Supposedly they use(d) the same OEM manufacturer as the reliable years.
But reviews are all over the place, as are the results. I guess it's more about luck!
KP might be correct about something upsteam causing failure. I don't know what that might be.
I know that our car has an igniter. I'm not sure what that does.
Consider also that the coils have ground wires. Perhaps a corroded contact could cause issues. But it's is a wild assed guess.
Look on the bank by the radiator, where it meets the intake manifold. Look for some ground wires which are attached with screws. Remove the screw, sand the wire contacts. Also under where the screw would go on the manifold.
You do have an unusual problem.
One suggestion is to buy some spares at a wrecking yard. Coils can last for a very long time, so the junkyard ones should work just fine.
The ECU is the ground that opens and causes the field collapse and coil saturation, then the Spark...I'd suggest you take an ole school timing light and place the inductive clip around the coilpack harness of each coilpack to view the firing consistency! The ignition process is very visible and you can find ignition problems really fast this way...New Hitachi Coilpacks giving you problem is hard to believe! I would suggest you invest in a new Crankshaft sensor at the crank pulley and transmission mating line!
Well I haven't really done anything yet besides put another duralast on there and drive. So far, no more problems. I was thinking, maybe the Hitachi's I got were fakes? They were only $40 each on Amazon and they don't actually say Hitachi on them.
The last one that failed was after less than one hour of just idling while I tried to troubleshoot and bleed the cooling system. I have driven for more than a week now on the duralast on the same cylinder with no problems.
I actually do have a real timing light so I'll definitely check that out. So basically I am looking for wander or instability in the firing?
can you afford to buy an oem coil (1) and try it? the napa coil (chinese)my mechanic put in would set the check engine light. he then bought an oem from dealer , that was years ago
Go to a junkyard and stock up on coils, front and back. They are usually OEM and very inexpensive. You can usually get 3-4 for the price of one new OEM coil.
Many years ago in an Engineering course, the Prof was lecturing about design life and automobiles. He opined that original equipment (OE) automobile parts were typical designed with a 100k design life -- the reason being that otherwise the parts became too big, heavy and expensive and economically it wasn't worth the cost.
[This doesn't mean that all OE parts are designed to last 100k or that all OE parts will fail when they reach their design life, just that there will be an increased failure rate of OE parts over time and that most, but not all, parts will reach their design life]
That said, I am the proud and original owner of a '97 Maxima SE, 214k miles. The ignition coil in cyl 2 failed in 2015, cyl 3 failed in 2016 and yesterday (2018) the coil in cyl 1 failed. I also had to replace the non-OEM replacement coil in cyl 2 with an OEM because the non-OEM coil, although working fine, kept throwing off codes and would have caused me to fail the CA emissions test.
How does this apply to you? The original coils (OE) have exceeded their design life, and every year you should expect an increase chance of their failure. Still, their failure rate should be pretty low.
As for non-OEM replacement, it is likely that they are not manufactured to the same standards as OEM parts, and will likely fail at a (much?) higher rate than OEM parts.
I am curious if the timing thing works out.
I also recommend that you test the condenser (simple test with a multi-meter). If it is failing, it might effect the non-OEM coils more than OE or OEM coils.
I was able to find a maxima in the junkyard with new Hitachi coilpacks for $8.43 each!!!!! I'm still laughing and enjoying them...I'm so glad to see someone else uses an old school timing light to check there coilpack operation... In this some thread I had a Nay-Sayer pretty much calling me a liar. Anyway I would check your spark plugs as well and maybe even changing them with new units...NGK, Denso, or even E3 worked great work 7 years in my 4th Gen...I'd say my car had better low end torque/acceleration with the E3 plugs...
I just put the timing light on it and the flashes seem mostly strong and regular, but maybe the odd one missing every once in a while. It's pretty hard to judge and unfortunately it's too fast to pick up on camera. The flashing also seems smooth and steady as I rev the engine. I checked #s 1, 2, 4, and 6 and they all seem the same.
Would it be really obvious looking at the light if there was a problem?
I have driven for a couple weeks now with no Hitatchis, 2 Duralast, and the four remaining original coils and haven't had any more issues. I'm thinking more and more that there is some issue unique to the Hitachis that killed them very quickly and seems to not affect the others.
yes, when mine went bad it was. you will be doing all 6 in due time, just like injectors, they all go bad as the weaker ones struggle to keep up with the stronger ones and eventually fail.
disagree.
I replaced ONE 8 years ago (100,000 miles , now with 175000 no failures.
disagree.
you are very lucky then, ask any max or other car owner and they will tell you a different story. you might get one a year to go bad, my original coils made it to 280,000!!!
If you saw it miss, it's firing time then that's an obvious missed ignition event, (not under load) remember during acceleration the cylinder pressure is higher causing even more resistance and may cause it not to fire consistently....
Another trick to isolate the coilpack from the sparkplug...Move the suspected coilpack to another cylinder and repeat your test again....
There's another trick is to reduce your sparkplug gap to .040" or .035" to reduce the gap distance therefore making it easier to jump...if you're still experiencing issues with that particular coilpack, you have a bad coilpack obviously...
But I just did that test on completely working coils, was that correct? I mean, there would be no point in testing a bad coil that way because they are absolutely dead.
Knowing the spark plug is good, do you think a missed event like that points to a problem with that particular coil or with the ignition system behind it?
Honestly though, it was also pretty hard to get it to even pickup the signal reliably, the clamp on my light is pretty big and was really hard to get it to fit around the wires and between the coils against the head and close all the way. I could see the flashing come and go with movement of the clamp. So maybe due to vibration it's just not picking up some events that are happening?
And for some reason, I couldn't get any flashing at all out of cylinder #6, but it's definitely firing because the idle drops dramatically when I unplug it. I figure this must be the clamp fitting around there and nothing to do with the coil.
I have not had any issues since doing the plugs 4,000 miles ago, until yesterday. Another of the new Hitatchi coils failed so I replaced it with autozone last night. Now I just got to school after a grand total of 48 miles, an another coil just failed. I don't know which one yet.
So what changed yesterday to burn two coils inside of 24 hours? I didn't run the A/C yesterday and today for the first time since this all started. That is the only possible thing that seems to be related to this. Is that possible?
This is now at least 8 coils failed since july.
I am going to put an oscilloscope on the coil trigger wires to see what the signal looks like. Does anyone have specs on like what the voltage and duration of the pulses should be?
They were from Amazon, the left side three from a 3rd party vendor, while the right side were direct from Amazon, but all junk. I have just contacted them to demand a refund despite being out of warranty but not hopeful. Their terms were 'if you open the plastic wrap, no returns/refunds' which I think is bull****. At least now I know for sure that their coils were at fault.
That's a really good price for those if they are good. Thanks, 'll look at a pair of those for spares at least.
Did they come in Hitachi packaging? The part number stickers are correct. But those appear to be easily recreated. Something about this makes me suspect some counterfeit coils from you know where..
Scratch the idea about Intermotor coils.. I'm seeing some bad review on the Advance site.. I keep a couple of extra coils that I've collected from junk yards. Strangely, I've not had a coil problem on multiple VQ30s with over 240,000 miles. Note that I have a coil secret. I run NGK V-Power copper plugs that get along well with older coils.
The plugs are NGK iridium but I'm not sure on the exact part number. Maybe still have the boxes so I will check tomorrow. They weren't the most expensive plug at autozone but the 2nd most expensive. They came gapped consistently at 0.042" if I remember correctly.
I just put in all six new 4,000 miles ago when I was last experiencing coil issues. The previous plugs looked really old but still had the correct gap.
I really do think now that its bad luck from multiple angles. Bad luck that several original coils failed close to one another, and bad luck that the Hitatchi set I bought was junk. Still haven't had a duralast fail for over 4,000 miles.
They were in white and red Hitatchi boxes but they were not positively sealed. No tape or anything on the individual boxes, and the plastic wrap around them inside the box was not sealed but also not cut or torn, so it was not designed to be sealed. I have no idea how they should come packaged.
But for the warranty stuff, even though they couldn't tell that you opened them, you could never return them for being defective because you would have to open them to install them in the first place to find that they were defective. I'll post up the packing tomorrow, still have it.
Today the last Hitachi failed, this one lasted over 4,000 miles somehow. It melted out just like the last one.
I can't believe I didn't notice it before, but every Hitachi, left and right sides, melted the same exact way.
Now at least none are left to fail.
Wow I never could find a new condenser for it, thank you. Isn't it wrapped up in the harness somewhere?
The fact that all your coils failed is highly suspicious. Something else is wrong, perhaps seriously wrong.
I know Hitachi coils are good - I recently replaced my 12-yr old coils with Hitachi's from RockAuto.com and they work just fine. However, the ignition circuit contains a part called "Ignition Condenser". This condenser/capacitor is there to minimize the voltage spikes during the ignition cycle, and thereby reduce the wear and tear on the coils. I strongly suspect that your condenser is bad, and that's why your coils are wearing out so quickly.
You can get a new condenser from here: https://www.nissanpartsdeal.com/Page_Product/SearchByName.aspx?Make=Nissan&Model=Maxima&Year=20 00&Submodel=&Filter=(2=VQ30DE;3=CAL;4=SE;5=AT)&Key words=ignition%20condenser . It's only $9 (plus shipping).
The condenser is integrated into the wiring harness; it's part of the wiring harness, on top of the engine, and a bit to the left (driver's side). To replace it, you may have to unwrap some of the electrical tape shielding/wrapping the harness.
Good luck, and let us know whether this does (or does not) solve your problem.
EDIT: I forgot this is a 4-gen Maxima (assumed 5-gen). You need to adjust the "nissanpartsdeal" link accordingly.
Thank you so much, the new one is on the way. It will be interesting to test and compare the capacitances of the old and new ones to see what's going on.
pics of said area where condenser is located please, i don't need to be guessing on this issue. have 2 new hitachi coils unopened for the front in the max ready to go on. i think 4 of my coils are also amazon and might be bad. i have code p0300 and code p 0304 as well and suspect bad coils and maybe the plugs as well that only have about 35,000 on them and are single laser plats. thanks
The EC section of the FSM has a nice picture on pg. EC-590.
The above page # is for my car (2000SE). You can just search your EC section for "condenser".
