Sebastian-1999 Nissan Maxima owner
Good day Maxima Org,
I am new to the organisation and I own a 1999 Nissan Maxima, I inheritted the car from my father.
I have a few issues I need to sort out and I don't have a Manual for my car:
Please assist, I would love for my First Car Ever to function fully.
- The lever to open the boot doesn't work,cable is still in tact though.
- The window controller for all the windows on the drivers side doesn't work,each window has to be operated from the door it has the up and down button.
- The window on rear left door doesn't open or close,it makes the sound that the motor is running but the window doesn't move and it's slightly open.
[*]The lever to open the boot doesn't work,cable is still in tact though.
~If it were me and the key worked fine for the trunk; I would leave well enough alone
Otherwise you'll need to open the trunk or pull up your carpet and verify the cable is still attached on both ends, and that the latch hasn't been pushed down for "valet mode"[*]The window controller for all the windows on the drivers side doesn't work,each window has to be operated from the door it has the up and down button.
~Replace the drivers side switch and go from there; junkyard FTW[*]The window on rear left door doesn't open or close,it makes the sound that the motor is running but the window doesn't move and it's slightly open.
~Regulator is bad, but I would just replace the motor and regulator together
Oh, for the best manual around download the FSM linked in my sig
smiller9883
Apr 12, 2015 02:31 PM
colinnwn
Jul 11, 2006 06:50 AM
