Timing belt replacement parts or kit recommendation
Old Nov 3, 2018 | 08:02 PM
markevans999's Avatar
1994 Maxima GXE. 130K miles.
belt or kit recommendations
what should be replaced at the same time also.
Old Nov 5, 2018 | 09:24 PM
Augustus Maximus's Avatar
Camshaft seals, tensioner and tensioner stud, crankshaft seal, thermostat, water pump.
Old Nov 16, 2018 | 07:52 AM
ac max 92's Avatar
2nd page in the 3rd gen classifieds. Looks like aminus21 has alot of your parts your looking for. Might be worth checking it out to see if he still has them? Price was great for all the stuff he had.
Old Nov 24, 2018 | 06:02 AM
tried contacting him. got no response.
Old Dec 11, 2018 | 07:31 AM
ac max 92's Avatar
Just an idea but maybe try going to his public profile and click on message to see if he has an email option?
Old Mar 9, 2019 | 04:31 PM
jkilmurray's Avatar
Gates tck104 kit on amazon. What I used.
Old Mar 11, 2019 | 09:07 AM
AzureblueZ's Avatar
Here are additional some Nissan Part Numbers, if you need them:
Timing Belt Tensioner 13070-42L00 $70.13
TB Tensioner Spring 13072-V5210 $2.45
TB Tensioner Stud: 13073-V5001 $2.43
Thermostat 21200-V5015 $17.19
Crankshaft Front Seal 13510-88G00 $5.73
Cam Shaft Seal 13042-D0101 (2) $9.66
Water Pump 21010-16E03 $93.44
Timing Gear/Sprocket 13021-0B700 $32.70
Crankside Plate 13022-V5001 $2.40 $2.40
Front/Snout-side Plate 13023-V5000 $3.77
Other considerations:
3 drive belts
Antifreeze
I always replace the tensioner when I replace the belt.
The 94 had a different timing belt than the earlier models. Just that one year, 1994. The rib-style of the belt was different. Make sure you are very specific about the year when searching. I went with a Gates timing belt and had good success. I have two different part numbers for the Nissan timing belt, but I'm afraid to post them because I can't remember which one is which. If you want to go Nissan specifically then call your local Nissan dealer and specify the year for the right part.
TWINTRBO
Mar 18, 2005 11:02 AM
MarkC
Jan 21, 2004 07:14 PM
HPSE
19
Jan 12, 2004 10:14 AM
Nissan-R
Mar 15, 2003 06:15 PM
djboo
25
Aug 11, 2001 11:23 PM
