Stuck in Park/No Brake Lights
Old Nov 5, 2018 | 06:16 PM
dlloyd90's Avatar
2006 Maxima, 118K Miles. Car is stuck in park, starts normally. Can change gears using the manual interlock. Now the brake lights don't work.!
Replaced stop light fuse, Battery Saver, and the two "electronic parts" fuses. Note that the "Battery Save Fuse" was bad. The rest of the car works fine. (except climate control - no fans, temp control, A/C)
Old Nov 6, 2018 | 08:57 AM
Fakie J Farkerton's Avatar
Check the switch on the brake pedal
Old Nov 6, 2018 | 11:05 AM
MadMax07SL's Avatar
Yeah, pedal switch, neighbor's Accord had that problem...
Old May 15, 2019 | 11:35 AM
KP11520's Avatar
Continuity tester touching the connectors on both sides of the brake pedal switch (Unplug it for access) and push on the Brake pedal. No sound or light means bad brake pedal switch as suggested above. Also make sure a plug didn't back out so it can't conduct.
smackdown85
35
Aug 21, 2023 10:05 PM
NC00DEK
Oct 10, 2019 12:03 PM
auveeb
May 18, 2011 06:11 PM
86MaximaZ
Oct 2, 2004 02:16 PM
tropher13
Jan 24, 2003 09:13 AM
