CNC machined bracket to bolt 370z Akebono Calipers to 95 thru 08
This just changed my life! A bracket made to fit the Akebono Calipers to the maxima. You will either need to machine down the factory 14" 370z rotors or you can just use Mitsubishi Evo X GSR 13.78″ (350 MM) rotors. This opens up so many new possibilities!
Link to brackets:
https://www.ebay.com/itm/Front-Akebono-Big-Brake-Caliper-Rotor-Upgrade-Adapter-Bracket-For-300ZX-Z32/142692776193?fits=Model%3A300ZX&hash=item213926f90 1:g:LqAAAOSw~89ah4Fa
Link to brackets:
thanks @ChrisMan287 I did the 996 front / rear calipers on the m3 with CSL rotors so for the maxima it seems fitting lol I found the calipers for $48 each (with core charge) but realistically $250 said and done if I don't return a core which im gonna have to ask about. EvoX 350mm rotors (Ill have to make sure the center bore is the same) and the adaptors is everything ? no line adaptors ? I take it now is the time to go stainless lol anyone do the rear calipers yet ? Even if I have to eliminate the E brake (since its a auto (not by choice it fell into my lap lol))
also @ChrisMan287 theres 3 other adaptors for the 300zx for "front big brake kits" for dif rotors and such, I take it I should just stick to the adaptor that was shared above and the evo 350mm rotors?
I can't confirm that the other brackets will work but I can assume that they will. You should be able to use stock lines but it won't hurt to switch to stainless.
No rear options that I can think of...
Dark99GLE
Sep 10, 2008 06:34 AM
AKOGAN
Jul 28, 2005 05:12 PM
