Had codes 1320 and 1445 -got them cleared
We put OEM coils, spark plugs, starter and ele ctronic ignition harness-got 1320 cleared We put new purge volume control, cleaned all hoses and parts and put new purge canister on-got 1445 cleared There are no codes showing now and car still just cranks and won't start still, battery is good,new fuel filter desperately need this car running.Any ideas? She's a 97 Maxima SE manual
If you have an upper oil pan leak then oil on the crank pos sensor is normal. Spray electric cleaner on it to clean it. If you have no spark then you have other problems. Electrical problems are the worst. These cars have a lot of grounding problems. Make sure cables are well grounded.
Now what to do???
Sorry it took so long to get back but we ran into a few problems with wiring, got that fixed too. I ordered all three sensors and all three are installed and now it's barely starting and at a VERY rough idle with a backfire and dies. It wouldn't start at all before but now what?any ideas?
Peach 97: we missed some backstory. Presumably the car was running when you added those parts / cleared those codes - is that correct?
but now it's not running at all? What happened, again ?
is the gas old ? What's the measured fuel pressure ? How do you -know- you have spark (not just because you replaced those parts - right?)
lots of help available here here but we only know what you tell us
2010MaximaSV
Jun 3, 2011 08:21 PM
rccardude909
23
Aug 23, 2005 02:00 PM
