A random spring fell out of my 5 speed transaxel
Old Sep 25, 2019 | 12:59 PM
garends's Avatar
While replacing my clutch. I was lowering the transaxel with a jack... and this small spring appeared on the ground. I wasn't able to see where it came from (inside transaxel...or outside)
The last picture shows where I found it after dropping the transaxel.
Any suggestions? Part of me wonders if the spring is not associated with my current project and had fallen down in the engine awhile ago...
Thanks!
Thanks,
Graham
Old Sep 25, 2019 | 01:01 PM
RA030726's Avatar
I'm nutty for Nissans
How did you drain the fluid?
Old Sep 25, 2019 | 01:53 PM
garends's Avatar
Out of the reverse neutral sensor
I drained it out of the reverse/neutral sensor.(I think that’s the sensor). It the big 40mm hole on the bottom.
thanks!
Old Sep 25, 2019 | 02:33 PM
RA030726's Avatar
Did it come from that? I haven't played with that thing because they alway break.
The 12mm drain plug is a pain to use but it's the safest way. I had to grind a wrench to fit in there.
Old Sep 25, 2019 | 02:37 PM
Laura's I35's Avatar
Looks pretty heavy duty to me, have any idea as to where it came from?
Old Sep 25, 2019 | 02:39 PM
Isn't it actually a transaxle - not a transaxle?
Anyway I was thinking the sroing may have been part of the clutch disc or the fork ??
Old Sep 25, 2019 | 02:40 PM
Sorry, should have read spring not sproing...!
Old Sep 25, 2019 | 03:13 PM
garends's Avatar
I think it is a detent spring
After reading around the forum, it sounds like it is a detent spring. There should be a ball bearing that goes with it as well. I will search for that once I get back home.
I must have unscrewed a wrong bolt possibly near the gear selector.
Does anyone know if the ball goes in first or the spring goes in first?
Old Sep 25, 2019 | 03:41 PM
RA030726's Avatar
I was thinking a detent spring too. The ones I know about are for the gears. The ball bearing goes in then the spring. Did you unscrew something with a flat head screwdriver?
Old Sep 25, 2019 | 04:10 PM
garends's Avatar
Not
I didn’t removing anything with a flathead on it.
I am still trying to locate where it came from. So strange.
Thanks again!
Old Sep 25, 2019 | 04:59 PM
garends's Avatar
Diagram
Just found this diagram of the detent springs from the 1996 FSM
Stlbluzoo11
149
Jun 24, 2015 04:59 AM
prappl
Dec 12, 2011 08:30 AM
MaximaSpd85
Jan 1, 2009 07:43 AM
panda_1
Mar 9, 2005 10:56 AM
