correct air box bolts?
Old Oct 3, 2019 | 01:07 PM
reallywildstuff's Avatar
I think the last person to work on my car (A/C) didn't put the stock intake air parts back together 100%. Please help me determine what's missing...
I appear to be missing a bolt (or something) that holds the one "downpipe" onto the "muffler" - this causes the assembly of black air tubes to be able to move around more than they should. I've attached pictures with red circles around what I'm missing (what I think I'm missing) as well as a parts link to hopefully point out the missing piece.
https://grubbsinfinitiparts.com/niss...&siteid=216759
Thanks -
Brian in Houston
Old Oct 3, 2019 | 02:51 PM
RA030726's Avatar
I'm nutty for Nissans
If you don't mind hardware store parts, a fender washer and m6x1.0 bolt about 20 mm long should do the trick.
Old Oct 3, 2019 | 03:03 PM
RA030726's Avatar
You are missing a rubber insulator with metal insert is you want it to be original.
Old Oct 3, 2019 | 03:23 PM
And the bolt is installed from the bottom, is that correct?
Looks like one of the ears on mine has also been helpfully broken off.
Maybe I need new parts...
Old Oct 3, 2019 | 04:22 PM
RA030726's Avatar
Yes it bolts from the bottom. If you went original the bolt would need to be longer than what I said above BTW.
Old Oct 3, 2019 | 04:27 PM
RA030726's Avatar
I have the parts if you need them.
Old Oct 4, 2019 | 09:11 AM
PH98I30's Avatar
Could go to a junkyard for parts?
Old Oct 27, 2019 | 07:03 PM
I could have gone to a junkyard, but inistead I bought JSutters’ parts. My original on the left (with air tube still installed) and his on the right. There is also a rubber sleeve that fits over a rubber pin on the back side - make sure you either get it or swap it.
reallywildstuff
Oct 28, 2019 05:16 PM
LastTraintoMEM
Feb 10, 2014 10:23 PM
limsandy
Jun 1, 2004 05:29 PM
sascuderi
32
Apr 18, 2004 04:31 AM
DCmax
Mar 25, 2001 09:20 PM
