Added tube for cool air and heat shield for my Berk intake...pic inside
Apr 15, 2004 | 01:55 PM
Just thought I would pass this along with summer around the corner. With two parts from Home Depot, make a small heat shield and extended the tubing to bring the outside air closer to the intake. Do you think this will do much? Guess it can't hurt.
Can get more pics here:
http://www.scuderi.net/car/
Apr 15, 2004 | 02:21 PM
i agree with you especially here in miami.
Apr 15, 2004 | 02:22 PM
but what exactly, part wise did you buy?
Apr 15, 2004 | 02:27 PM
interesting...I was working on
designing the same thing for my frankencar intake....would be interested to know EXACTLY what parts you used!
Apr 15, 2004 | 02:54 PM
Quote: but what exactly, part wise did you buy?
In the Dryer duct section..one 4 inch elbow
Next to it, in the air duct section...4 inch collar.(flat sheet of metal with a hole in the center to pass the tube through)
What I did is cut the collar down to fit the spot, then bent it at the bottem and bolted it to one of the holes that the original air box was bolted to. The elbow tube passes through the collar and slips over the end of the scoop coming from the front of the car. (you have to remove the loose connector on it to allow the home depot tube to slip over)
Then painted it black, using high heat spray paint (for grills), also form home depot.
I them place some weather striping around the heat shield to prevent cuts from the sharp metal edge.
Easy!
Apr 15, 2004 | 03:07 PM
I would really like to see more pics of this.
Apr 15, 2004 | 03:33 PM
the only prob is that i removed that black thing when i installed my Berk intake, was i not supposed to?
Apr 15, 2004 | 04:51 PM
i dont think that shield is really going to block any heat. and it has to be a material that wont heat up.
you really need something like this
Apr 15, 2004 | 04:57 PM
where would u get something like that?
Looks nice and functional. Hope it works well.
Apr 15, 2004 | 05:03 PM
Quote: where would u get something like that?
in a chevy tahoe.
K&N doesnt make one for us, i just used that pic to show that you need something that really blocks heat.
Apr 15, 2004 | 05:30 PM
You're right. I looked around to buy one like on the K&N set up, but couldn't find anyone that would sell just the heat shield. They do sell a piece of curved metal that goes on top of the filter, but it didn't seem functional
Even if my shield doesn't do much to block heat, it is still needed to support the tube.
Apr 15, 2004 | 05:32 PM
so was i not supposed to take off that black thing that brings in air. when i installed my intake?
Apr 15, 2004 | 05:40 PM
Quote: so was i not supposed to take off that black thing that brings in air. when i installed my intake?
i removed mine with my GAB setup. i dont think it brings that much air in
did you relocate the sensor that was on the scoop?
damn that engine is shiny and pretty
Apr 15, 2004 | 05:41 PM
There is no law that says that you cannot take it off. Most people have left it on just to get more air in. I am going to leave mine on when my Berk gets here next week.
Apr 15, 2004 | 05:43 PM
Quote: Just thought I would pass this along with summer around the corner. With two parts from Home Depot, make a small heat shield and extended the tubing to bring the outside air closer to the intake. Do you think this will do much? Guess it can't hurt.
That is really a cool idea, props to you. Am I missing the heat shield?
Would you take more detailed pics please.
Apr 15, 2004 | 06:13 PM
Ok, I'll take more pics but I won't be able until tomorrow (sorry!)
To PearlWhtMaX2000, I left the front air scoop in since I didn't want to have to move the temp. sensor, and I was planning to add the tube to direct air to the Berk intake. Where did you move the temp sensor to?
Apr 15, 2004 | 06:40 PM
Youd probably want something to cover the midpipe too. Exhaust wrap perhaps?
It gets really hot after a while of running the engine...and theres not point in letting in cooler air through the cone, when it still heats up after, due to the aluminum midpipe (for the berk).
Apr 15, 2004 | 06:45 PM
Where is this midpipe?
Apr 15, 2004 | 06:48 PM
Quote: Where is this midpipe?
The longish metal thing, in these pics it's the part with the K&N sticker on it.
Apr 16, 2004 | 12:14 PM
As promised, can see more pics here:
Apr 16, 2004 | 03:33 PM
i tried something simlar to that last summer by running 4" drier hose from the bottom of the car to the filter, but your idea looks good i may try some thing else like that, but i dont have the scoop on my car with my berk intake i took it off a long time ago
Apr 16, 2004 | 05:06 PM
i need better pix, i went to home depot today totry and do it but i didnt know what i needed, and where exactly to run it.
Apr 16, 2004 | 05:39 PM
Quote: i need better pix, i went to home depot today totry and do it but i didnt know what i needed, and where exactly to run it.
Its easy. In dryer section, 4 inch diameter 90 degree elbow. And to the section to the left (same isle) a collar (flat piece of aluminun with a 4 inch hole in the middle.) You have to cut the collar to make it narrower to fit; its too wide as is.
Just attact the elbow to the end of the orignial scoop (Very first section of the orginal intake on the front of the car), pass the other end of the elbow through the collar, then bolt the bottom of the collar to one of the open holes the original intake used, and your done!
The fouth pic down has the best view
www.scuderi.net/car
Apr 16, 2004 | 05:58 PM
i was thinking about another way.
what if i cut a hole in the bottom plastic panel on the bottom of the car and run the tubing up from there?
Apr 16, 2004 | 06:28 PM
I'm sure that would work too.
Apr 16, 2004 | 06:56 PM
Hey thank you man! Its great that you took the time like that to help out fellow orgers! Its greatly appreciated!
Apr 16, 2004 | 07:52 PM
There's an org member that did this. Had it angled a little bit at the bottom so more air would come up while driving..spray painted it black also so it's not even noticeable.
Apr 16, 2004 | 07:57 PM
Quote: Hey thank you man! Its great that you took the time like that to help out fellow orgers! Its greatly appreciated!
Your welcome, but to tell you the truth, I am a novice and you guys (& gals) have helped me out over the years, so I am more than happy to return the favor when I can.
Apr 17, 2004 | 12:05 PM
Quote: There's an org member that did this. Had it angled a little bit at the bottom so more air would come up while driving..spray painted it black also so it's not even noticeable.
WOULD YOU HAPPEN TO KNOW WHO?
Apr 17, 2004 | 03:24 PM
just did this mod today, it kinda felt like it was restricting air flow, didn't seem to have the acceleration it had before i put the tube on. oh well, i'll just return the parts.
Apr 17, 2004 | 09:37 PM
30585: I don't remember the ID.. I don't think that member even frequents/posts around here anymore. He had a dark colored max, if that's any help..maybe someone else remembers.
Apr 18, 2004 | 04:31 AM
Quote: just did this mod today, it kinda felt like it was restricting air flow, didn't seem to have the acceleration it had before i put the tube on. oh well, i'll just return the parts.
Not sure I am following, how did it restrict the air?
