Low speed wobble
Old Dec 19, 2019 | 05:29 PM
Paid84's Avatar
Low speed wobble
I got this low speed wobble on my 16 maxima.My rims are not bent . What Else can it be?
Old Dec 19, 2019 | 05:42 PM
wild willy2's Avatar
Originally Posted by paid84
i got this low speed wobble on my 16 maxima.my rims are not bent . What else can it be?
cvt?
Old Dec 19, 2019 | 06:39 PM
Paid84's Avatar
My cvt seems good
Old Dec 19, 2019 | 07:32 PM
Mason Hatcher's Avatar
Originally Posted by wild willy2
cvt?
lol,
Oil pressure problem- CVT
Vibration- CVT
Wobble-CVT
Won't start- CVT
Engine miss- CVT
out of gas? No, it's the CVT
Old Dec 20, 2019 | 12:22 AM
slava's Avatar
Have you checked your tire pressure?
Old Dec 20, 2019 | 03:19 AM
Paid84's Avatar
Tire pressure good and rotated tires still same wobble feeling.I also have brand new Michelin tires to
Old Dec 20, 2019 | 04:40 AM
Mr.Santos's Avatar
Originally Posted by Mason Hatcher
lol,
Vibration- CVT
Wobble-CVT
Won't start- CVT
Engine miss- CVT
yea its the CVT for sure , ummm alignment maybe not sure check axles, hell take it to a dealer and find out what the problem is since everything everyone is telling you to check you checked.
Old Dec 20, 2019 | 05:46 AM
Paid84's Avatar
I took it to the dealer and they found nothing wrong.It also vibrates on the highway to mainly on the right side.They balance the tires and still no change twice.
Old Dec 20, 2019 | 07:08 AM
J_A_D_2002's Avatar
I went through this before, was at all speed though. Turned out the guy that did my alignment did a half-*** job.
Did you get the tire balanced and aligned at the same place? Also, if you had the tires on before alignment was done, they could have been worn unevenly.
If it isn't that, if the front axle is bent you would feel it in the steering wheel. The rear you wouldn't but you would feel it all the time. Does it reduce when you turn at all?
I am sure it isn't the CVT, The easy check is to while moving, pop it into neutral, if it wobbles, not CVT.
Old Dec 20, 2019 | 07:31 AM
Paid84's Avatar
It's not cvt I tried it in neutral while driving nothing change.I haven't got a alignment yet but I tried different sets of tires and nothing change
Old Dec 20, 2019 | 07:57 AM
J_A_D_2002's Avatar
Is it only low speed? Or high speed as well? Could be alignment but if you haven't done that the tires maybe worn so they will still vibrate (but that is more obvious in high speed)... so that is strange...
Are you the original owner? Ever hit a huge pothole?
Old Dec 20, 2019 | 08:03 AM
Paid84's Avatar
Wobble at low speeds and vibration on the highway.Im not the original owner. This car is certified
Old Dec 20, 2019 | 08:28 AM
2young2retire's Avatar
I had this same problem a few years ago and it turned out to be a broken belt in one of the tires. It would balance out ok but had a small wobble when spun for the balancing. Replaced the one tire and the wobble went away. Good luck and let us know what was the solution.
Old Dec 20, 2019 | 08:29 AM
J_A_D_2002's Avatar
When I was having a similar issue, I got another Nissan service department to take a look at it. Said specifically, that I worked with x-dealer/service and this issue is still not resolved.
If it isn't the alignment, than I would say axle but there isn't a way to confirm that without a full on facility to test it. Sadly, certification only really addresses catastrophic car failures, this is more comfort, but I get it; we all want it perfect, especially if you just got it recently... I would recommend getting a second opinion from another Nissan service. Sorry if that is no help.
Old Dec 20, 2019 | 08:42 AM
Paid84's Avatar
I tried to different dealers and nothing wrong.I might go back or trade in for audi a7
Old Dec 20, 2019 | 09:08 AM
The only other thing you may try is have the dealer swap the tires from another vehicle and then drive it. If the problem persists then it is not the tires and you have eliminated one variable.
Jaxmax17
May 1, 2019 06:16 PM
rablaze93
Feb 4, 2018 12:16 PM
NCSUpilot
Sep 14, 2014 03:01 PM
po8pimp
Aug 25, 2009 06:00 PM
big dave
43
Feb 23, 2007 02:55 PM
