Lower gas mileage?
Old Feb 17, 2020 | 12:40 PM
neo1967's Avatar
Lower gas mileage?
I cleaned the throttle bodies and MAF sensor this weekend now it seems as if I am getting poor gas mileage? Is it common to get lower gas mileage after cleaning? Throttle response is quicker and less hesitation and cold start idle remained the same.
Is there something else I need to do?
Old Feb 17, 2020 | 12:44 PM
NisCal17's Avatar
I think your MAF is malfunctioning. I know that if MAF is working incorrectly the car will run rich.
Old Feb 17, 2020 | 04:06 PM
compyelc4's Avatar
Why did you find it necessary to clean the TB and MAF? Curious.
Old Feb 17, 2020 | 05:17 PM
My thoughts exactly. The MAF is a very sensitive piece of equipment. I wouldn't clean it unless it was known to be contaminated with oil vapors etc (assuming an oiled K&N filter was in use).
Old Feb 18, 2020 | 03:06 AM
wild willy2's Avatar
It's a very easy clean, just do not touch it!!
Old Feb 18, 2020 | 05:20 AM
neo1967's Avatar
No just used a Mass Air flow sensor cleaner to clean the mass air flow sensor.
The throttle bodies were dirty and I was getting hesitation and poor throttle response so cleaning the throttle bodies definitely made a difference in performance.
Just the lower gas mileage is now an issue.
Old Feb 18, 2020 | 04:24 PM
Sugardaddy1979's Avatar
What temperatures are you driving in? Colder weather can reduce fuel economy.
Old Feb 19, 2020 | 09:32 AM
neo1967's Avatar
80-90 degrees
Old Feb 19, 2020 | 12:25 PM
MONTE 01&97 SE's Avatar
Could be a result of the below:
https://www.bellperformance.com/blog...blend-gasoline
Blame The Winter Blend Gasoline. ... Winter gas is more volatile and evaporates more quickly, so it is ideal for it is used in the colder air of winter. In terms of gas mileage, you get better mileage on summer blends than winter blends because the summer blend gasoline has about 2% greater energy value than winter blend.Dec 2, 2010
Old Feb 20, 2020 | 08:07 AM
neo1967's Avatar
Do you think doing a Accelerator pedal released position learning, throttle valve closed position learning and idle air volume learning would fix the issue?
Disconnect the battery?
Old Feb 20, 2020 | 09:18 AM
Richard66's Avatar
"It seems as if I am getting poor gas mileage" You didn't post any numbers on mileage or how you figure it. Your cleaning was done on the same weekend as your reported low mileage, not nearly long enough run time to get a accurate reading on fuel usage. The most accurate reading comes by the manual method of fuel used divided into miles driven.
Old Feb 21, 2020 | 06:05 AM
Steptide's Avatar
I use non ethanol gas, and in winter my gas mileage is always worse than summer. Some due to letting my car warm up, and some due to the fact that your car just gets worse gas mileage in the cold. Don't forget, using heat, rear defrost, heated seats/steering wheel, all contributes to worse gas mileage. Also tire pressures in the winter will almost always be lower than in summer. Even if your tires are at the right pressure, the summer heat will raise the pressure automatically and will give you slightly better gas mileage
Old Feb 21, 2020 | 09:24 AM
compyelc4's Avatar
Op said his is in 80-90 degree weather, not cold winter.
ShunDoe
Jun 1, 2016 09:31 PM
Gizm0
Nov 8, 2010 07:32 PM
MaximaFan4140
Jul 29, 2009 06:47 PM
remembermorriso
Nov 24, 2005 11:56 AM
