Hi I'm brent
Old Mar 6, 2020 | 10:18 AM
Brentarp3's Avatar
Hi I'm brent
I have a 2005 Nissan Maxima 3.5sl it was given code po770 so I put a vaulve body in it and now it is giving code for torqe converter clutch switch. But it you take off battery cables it runs perfect for a while till code kicks on. Can anybody help me fig out witch one it is and what to do please.
Old Mar 20, 2020 | 05:30 PM
oldblackie's Avatar
Maybe give you tube a try, it's surprising the info they give out.
Old Mar 21, 2020 | 03:56 AM
Turbobink's Avatar
I’d suggest that you post up all the codes you’ve gotten/you’re getting.
https://www.autocodes.com/p0770_nissan.html
Old Mar 22, 2020 | 06:35 PM
Brentarp3's Avatar
Codes
It is giving codes p0740 now but was giving code p0770
Old Mar 23, 2020 | 03:19 AM
Turbobink's Avatar
Both of those DTCs identify a couple/few identical common causes. Have you made sure those have been addressed?
Also, you’ve stated that you’ve replaced the VB. I’m assuming with a used/salvaged unit?
Those DTCs don’t indicate a failed/failing VB. They indicate a failed/failing shift solenoid.
Perhaps some diagnoses related to the individual shift solenoid indicated by the DTC would be appropriate.
bassmann
Feb 26, 2020 05:40 PM
Komax
Mar 11, 2005 03:04 PM
MaXi-MaMa
Jan 8, 2005 11:03 AM
Guttermouf5150
Jun 14, 2004 10:59 AM
