I’m looking to change my stock high halogen high beam bulb to an aftermarket LED however I couldn’t find any H9 led bulbs.
I found a decent H11 led bulbs for the high beam but I am not sure if it will work at all, and if I will need to do any adjustments/cutting or a simple plug and play will work.
please let me know as it’s the first time trying it.
i personally didn't but that's just me. I have semi smaller hands so i reached in. it was VERY tight and hurt a little bit without removing anything for better access. I didn't like the hikari i put in an 03 Camry. I went with the beamtech because they do not have a fan and run silently.
Okay, thanks!
I'll see if I can exchange for beamtech as well then
Recently installed some from Diodedynamics. Cost $150 for the set, great bright color that is very close to the DRL color. Most reviews that i saw or read had them ranked in the top 3.
The Top photo is factory LED Low Beams and aftermarket LED Fog lights (same brand I linked my fog lights get some moisture in them but my High beams don’t have that issue) and the lower picture is Factory Low Beam LED and the Aftermerket LED High Beams that I linked.
I have the hikari h11 LED also as my brights and I love them
im new to the forum. Do these these headlights throw an error?? When I did this on my mini it threw a highbeam malfunction code. I was wondering if its different on the max.
