(pending) P0303 - Misfire cylinder #3 question...
I have an '03 Maxima with about 156,000 miles on it and it started knocking quite bad and wanted to stall when it knocked but never stalled. I always use 91 octane and get my oil changed on time. I pulled a (pending) P0303 there was no CEL at all. After many searches on this site most people say it's more than likely the coil pack. Since I was going to have to remove the IM to get to the coil, should I replace all coils, spark plugs and fuel injectors while I have it open? I add in fuel injectors because they can also cause the misfire. I've already replaced both valve covers and replaced my spark plugs as well at around 127,000 miles. I plan on keeping this car for as long as I can because it's still in amazing shape and no rust (in Los Angeles). BTW, I was planning on buying Hitachi coils from Rock Auto. I would also get the spark plugs and fuel injectors from there as well.
I'm not the best mechanic, but I have take the IM off before, but that was about 6 years ago so I'm still a little nervous about doing it, but I know I can. But any reminder tips would be great.
So bottom line, should I replace all (3) Coils, plugs and injectors or just the one for #3 cylinder?
You have the right idea.
I would replace all coils with Hitachi's since it's a PITA to constantly take the manifold off and if you have the money, i would do the spark plugs while in there (NGK platnium if it was me)..
I don't see a need to replace injectors.
Great thanks. I was planning on the Hitachi coils and replacing all of them. Ok on the spark plugs, I guess even though they aren't that old it's good to replace them since I'm in there and they are that expensive.
Thanks again for your reply
HSVMaxima
Mar 15, 2009 04:36 PM
ihatemymax
Sep 15, 2006 03:18 PM
