Does your 7th gen engine burn oil?
Hello,
I'm just making this thread to see how common for the 7th gen Maximas' engines to burn engine oil. Leaks not included here. Key word is burn oil.
We have an 09 (93k miles) and an 11(96k miles). The 09 burns about half a quart every 2k miles, using Pennzoil Synthetic 5w30. The 2011 doesn't burn a drop.
Otherwise both cars are in excellent condition.
So:
1. Does your engine burn oil?
2. What oil do you use (synth vs dino)? high mileage vs non-high mileage oil?
3. Oil grade
Let me know
So:
3. Oil grade
Let me know
Hello,
So:
3. Oil grade
Let me know
So:
3. Oil grade
Let me know
My 09 with 440,000 miles doesn't seem to burn any (i say that as it is hard to measure a delta and I change every 5K anyway) I was concerned at one point as I had leaky valve covers. But replaced and all is fine.
Mobil 1 Synth (reg non-high mileage/non extended mileage/non other marketing advert)
5W-30
5W-30
If you only ran PUP for one interval, not uncommon to get a little consumption when switching formulas. I've never run anything but M1, although I've heard that engine noise/smoothness may be a little worse with the M1. What do you mean by smoother?
Smoother as in smoother and quieter than M1 especially on cold starts.
2009 116k
Never loses a drop.
Valvoline Synpower w/ Maxlife replacing 1qt w/ Lucas Heavy Duty Oil Stabilizer because I like running a VPS oil system cleaner every 15k and I want to clean SOMETHING out of her when I do.
2007 Sentra 2.0 on the same program and 2001 5.5gen Max previously. Same results.
Never loses a drop.
wope
20
Oct 10, 2011 01:19 PM
rawbutt
23
Sep 4, 2009 10:44 AM
