Sunshade/rear area/Dashboard Help
Old Jul 17, 2020 | 10:03 PM
Mikey319's Avatar
Hello, I’m kind of out of options. I had my vehicle inspected by a DTS (dealer technical specialist) that Nissan Consumer Affairs sent. To no surprise, they found nothing wrong after driving my car 32 miles ))).
I recorded these two videos a day later. Granted the sounds are intermittent but I don’t understand how they heard none. It’s my rear sunshade, the front dashboard is squeaking/creaking over bumps, and when I have a bassy song playing, the rear deck lid and two side pieces rattle. Again. Not verified by the DTS )). *I* fixed one of the sound by tightening a screw in my door panel myself the same day and fixed one of the rattles. I am so dissatisfied with Nissan right now. I just want my car fixed . do you guys have any suggestions on what to do? It IS out of warranty. (49k miles)
Old Jul 18, 2020 | 04:30 AM
Nmax5150's Avatar
No dealer will say they hear anything.. Rattles and squeks that only happen once in a while is a Pandora's box..
There are so many more important things in life at the moment than a rattle you hear every once in a while..
Find something to fill your day or turn the radio up...
Old Jul 18, 2020 | 06:09 AM
Mikey319's Avatar
That’s the issue. I’m paying all this money for a car and its NOT just once in a while. It’s usually daily. Just intermittent. Turning up the radio doesn’t help.
Old Jul 18, 2020 | 10:22 AM
Nmax5150's Avatar
Taking it to the dealer will not get you any resolve... Advisor will write you up and car will go untouched.
Trust me on this.. We call these people quacks..lol
Old Jul 18, 2020 | 10:34 AM
Mikey319's Avatar
well, I guess I’m gonna be a quack, because I can’t stand it. Its pretty consistent and turning up the volume doesn’t help. It didn’t do this in my 2017, so why should it do it in my 2018?
Old Jul 18, 2020 | 11:18 AM
denoose's Avatar
Were you actually able to locate the source of the rattle?
Old Jul 18, 2020 | 11:44 AM
Mikey319's Avatar
I’m not sure where on the sunshade. I just know that it is coming from there. I circled where the other noises are coming from. The rear deck lid itself, and those two side pieces where the airbags are. I feel like it’s a simple fix 🤷‍♂️
Old Jul 18, 2020 | 03:05 PM
Nmax5150's Avatar
Call Nissan and tell them you have a rattle, and it has make your quality of life so bad that you want a new car..
Lol
Old Jul 20, 2020 | 09:39 AM
dmstangu's Avatar
Rear rattle: stick two small pieces of foam (like home door/window insulation) on the inside of the lip of the sunshade housing.
https://maxima.org/forums/8th-genera...ml#post9168427
Dashboard rattle: stick two small rubber triangles under the instrument cluster "hood"
https://maxima.org/forums/8th-genera...ml#post9154589
Old Jul 20, 2020 | 09:45 AM
Mikey319's Avatar
that video I posted is with the sunshade up. Not sure if it will help me with that or not. I’m sure it’s worth a try. Thank you!
that’s for a buzzing sound it seems. Mine only occurs over bumps and is definitely not a buzzing noise.
Old Jul 20, 2020 | 06:06 PM
denoose's Avatar
Have you had someone else drive, and sit yourself in the back - you might luck out and isolate the noise YOU are hearing...
Old Jul 20, 2020 | 06:30 PM
ALRONDON's Avatar
My noise in the back went away when I took it to the dealer and they changed the rear struts under warranty....Only occurred when going over bumps
Old Jul 21, 2020 | 09:14 AM
Mikey319's Avatar
That’s the issue it’s intermittent at times so I’ll never know when to have someone else drive it. It just happens. From what I can tell I know the area it is coming from.
Old Jul 21, 2020 | 09:17 AM
Mikey319's Avatar
hmmm. I doubt they’ll replace those for me. Are they part of the 3/36 or 5/60 powertrain warranty? Bc my 3/36 is expired due to mileage. I had a creaking noise from the back of my car. I’m still not sure what it is and it appears to be gone for the time being but the other noises are there.
Old Jul 22, 2020 | 02:43 PM
Kenwood's Avatar
I had this sunshade rattle as well, but my issue was easy to identify. The roller on pass side fell out, so when retracted it allowed enough slop that it rattled. I noticed the one side was missing a wheel, and subsequently looked/found on floor the actual wheel. So far it has remained, but will express concern to dealer when I go in if it falls out again.
RAINMANYEH
Jan 11, 2013 08:33 PM
MAXD-OUT
Dec 6, 2004 07:50 AM
