Temperature reading up and down
Old Nov 23, 2020 | 06:50 PM
Texakinz's Avatar
Has anybody have issues with the car temperature fluctuating up and down when on idle. Temperature gauge goes a little above the halfway mark and stays there until i start driving again.
Old Nov 23, 2020 | 07:32 PM
MaximusN8's Avatar
I've never had that issue, but if it isn't going all the way up and over heat I wouldn't worry about it. Check your coolant levels, look around for any leaks and just keep an eye on things. I think it's fine.
Old Nov 23, 2020 | 11:54 PM
LtLeary's Avatar
Could be the elecric fans, stuck thermostat, radiator leak, or water pump. I am leaning toward fans. Do you know when the last coolant service was performed? Could be you didnt fill it completely so with engine cold, check the level by removing the radiator cap and look there instead of reservoir.
Old Nov 24, 2020 | 03:59 AM
Texakinz's Avatar
I had the Radiator, Thermostat, upper and lower hoses replaced March of last year. I check the coolant level every other week and it’s all good, even the reservoir.
2010 Maxima with 155,000 miles.
Old Nov 24, 2020 | 10:36 AM
mahanddeem's Avatar
It should not fluctuate. You have an issue somewhere.
Old Nov 24, 2020 | 10:59 AM
LtLeary's Avatar
Yep, now down to fans or pump.
feotto
Nov 22, 2019 04:59 AM
Brandon J. Wood
Dec 29, 2015 10:17 PM
ShocknAwe
Apr 29, 2013 01:38 PM
NixMaxGLE
Jul 23, 2006 07:36 PM
ladeesman
Nov 7, 2002 04:22 PM
