Master switch replacement
Old Dec 6, 2020 | 03:54 PM
English's Avatar
I have an 09 maxima, my passenger window was not working from my master switch on the drivers side but,it would work on the passenger side itself I changed the master switch,both the passenger and drivers windows work perfectly but now none of my rear windows,does not work at all I have power in the doors because I checked. if the doors lock and unlock from the new master switch and it does but neither window work from the master nor the doors themselves and ideas?
Old Dec 7, 2020 | 08:12 AM
Richard66's Avatar
Is the new master switch OEM or aftermarket?
Old Dec 7, 2020 | 03:17 PM
LtLeary's Avatar
Well two things to check
1.) Note that there are two different Master Switches for the 09 (and others although I can only speak from my experience) Take a look at the old and see if both the front and rear have an "A" on the ALL switches. You many have gotten one that isn't for your car. If the original had As and the replacement doesn't (or the inverse) you have the wrong switch.
2.) Take a look at the lock button on the Master Switch. If it is turned on, the rears shouldn't work. Same with the locks.
Old Dec 7, 2020 | 03:22 PM
English's Avatar
This is exactly what happened my original master had only 2 A’s whereas the new master had all A’s making it the wrong master thanks LtLeary
Kjizzle
Nov 25, 2016 07:16 PM
The Law
Jan 11, 2011 08:18 AM
MOHFpro90
Jan 7, 2008 07:28 PM
berts689
Sep 22, 2006 07:45 AM
