cel p0507?
Old Dec 23, 2020 | 02:52 PM
chance1st's Avatar
cel p0507?
does anybody have any info on this code for a 2014 maxima? if so could you let me know what i need to look for to fix this problem
Old Dec 23, 2020 | 06:13 PM
Captive8's Avatar
Link to online FSM......look in the EC section
https://www.my4dsc.com/nissan-info/f...ervice-manual/
Old Dec 24, 2020 | 08:42 AM
LtLeary's Avatar
Captive8 is correct but lets get you a little closer. You are looking at a bad pcv valve/hose or air leak most likely
Here is the test procedure for the P0507Diagnosis Procedure
1. CHECK PCV HOSE CONNECTION Confirm that PCV hose is connected correctly.
Is the inspection result normal?
YES - GO TO 2.
NO - Repair or replace malfunctioning part.
2. CHECK INTAKE AIR LEAKAGE
  1. Start engine and let it idle.
  2. Listen for an intake air leakage after the mass air flow sensor. Is intake air leakage detected?
YES - Discover air leakage location and repair.
NO - GO TO 3.
3. REPLACE ECM
  1. Stop engine.
  2. Replace ECM.
maxxxdout
Apr 2, 2011 05:12 PM
Smokey
Mar 3, 2004 07:48 PM
scottcarlsonMAX
Dec 25, 2003 10:19 PM
JR_Anders
Aug 10, 2002 11:27 AM
