Windows rolling down automatically after car is turned off
Old Mar 25, 2021 | 09:30 AM
Shelly1970's Avatar
I am new to this forum and I need some help please. My windows on my 2017 Nissan maxima keep rolling down automatically when my car is turned off. My key FOB doesn't work properly and when I hit the lock button on it it rolls down the windows sometimes. My FOB unlock button plate came off so there is no way I can use FOB to unlock the car, I have to use the little button on the outside of the door handle to unlock it. Is there any way to make the windows stop rolling down automatically and disengage it? I am worried about it at night and inclement weather with this issue going on. Would appreciate any advice anyone can give! Thanks!
Old Mar 25, 2021 | 11:13 AM
robtroxel's Avatar
It sounds like a bad body module. You have to visit the dealer to be sure.
Old Mar 25, 2021 | 12:04 PM
Richard66's Avatar
What happens with the other remote??
Old Mar 25, 2021 | 01:03 PM
TallTom's Avatar
Its the keyfob that is the culprit. On a normal/functioning keyfob, if you press and hold the unlock button, the two front windows will go down automatically when the keyfob is in range of the car. I do this on hot days when approaching the car to start letting the heat out.
Easy way to test: leave the keyfob at home and take the car out for a drive with just the key, then turn the car off when the keyfob sitting at home.
Old Mar 25, 2021 | 01:20 PM
Shelly1970's Avatar
Thank you all for the help. I only have one key FOB too for it. Definitely need to get another one.
Old Mar 25, 2021 | 01:23 PM
Shelly1970's Avatar
I don't have another remote, only the one. And my car is a push button start.
Old Mar 25, 2021 | 04:07 PM
NisCal17's Avatar
How is he supposed to take the car for the ride without keyfob? There’s no way he can even unlock the car without keyfob being in range.
Old Mar 25, 2021 | 04:10 PM
NisCal17's Avatar
There’s automatic roll down programmed into the software. One is triggered by keyfob and the other one is safely feature.
is your car flood damaged?
Old Mar 25, 2021 | 05:02 PM
Shelly1970's Avatar
No it is not damaged ar all or flooded. It is still almost brand new cat, has 35,000 miles on it. It just recently started going haywire with the windows constantly going down by themselves a couple days ago. Have it parked in garage right now. Just want an easy fix until I can get it to a dealer so that the windows will stop rolling down
Old Mar 25, 2021 | 06:54 PM
Richard66's Avatar
Start the car with the keyfob, take the key out of the keyfob, leave the keyfob in the house then drive away and comback and park, turn off car and exit, see if the windows roll down.
Old Mar 25, 2021 | 11:09 PM
NisCal17's Avatar
Technically it can be done. But I wouldn’t do that...
I would probably start the car and isolate keyfob in some foil or something and do the same without leaving the house. 😜
Old Apr 5, 2021 | 08:33 PM
lindros2's Avatar
where is the other key fob?
Did you lose it? or never have it?
Have you replaced the battery in the key fob?
Old Apr 6, 2021 | 06:51 AM
Shelly1970's Avatar
Info worked!!!
Originally Posted by yufamily0168
Remove the battery from the key fob.
Flip the key fob over, then push the small release latch.
Pull out the hidden emergency key from the bottom of the fob.
Insert the key in the driver’s side door and unlock it to enter.
and use the key inside the fob to lock and unlock the doors.
To start the car. Simply press the key fob against the START/STOP button as you step down on the brake
Thank you so much, I did that this morning and it worked!!!!!
Old Apr 6, 2021 | 06:54 AM
Shelly1970's Avatar
Thank you for the advice! It helped!! I did it this morning and ni issues now! 😁😁😁😁😁😁😁😁😁
Old Apr 6, 2021 | 11:44 AM
Shelly1970's Avatar
Info worked!!!
I want to thank all of you who helped with my issue. I took the battery out of key fob and took key out of it to lock and unlock doors. Started it by putting the fob on the start button and so far so good. I will see if it works overnight because usually that's when the front windows randomly roll down(hours after it's been parked!) This site is great and so happy I have this forum to ask anything I need to know! Thank you!!!!!!😁😁😁😁
Old Mar 13, 2024 | 04:34 PM
Beachgal's Avatar
PLEASE HELP WINDOWS WONT STOP ROLLING DOWN AUTOMATICALLY!
Can u please help me. I have a 2014 nissan maxima. I've done something with my key fob & I have no idea what I did. When I went to lock car the windows automatically rolled down so it was pointless to even lock the car. Somehow I fixed that issue ( have no idea how I did it). Now its no longer rolling windows down when I lock it. They have started automatically rolling down when I unlock it. It wouldn't be an issue until it is storming or I'm in an unsafe area. Can you please tell me how to fix this issue. Again the windows automatically roll down when I unlock car with key fob. How do I stop this or deactivate it?
Beachgal's Avatar
Please help windows wont stop rolling down automatically
Jules Maximus
Oct 15, 2010 09:23 AM
PENROSE2006
Mar 11, 2008 07:45 PM
one_fast_max
Dec 5, 2007 01:42 PM
nismo-max500
Oct 21, 2003 12:16 PM
8702
Jun 30, 2002 01:40 PM
