Brakes and lugnuts
Old Apr 9, 2022 | 02:00 PM
Bificus99's Avatar
Brakes and lugnuts
I'm a Motorweek fan and of the late Pat Goss. On one of his segments he discussed lugnuts and how the new ones are capped and they can swell and they will get hard to remove. I first hand found out that my lugnuts had changed size and my oem tire wrench would not work. Went to the local dealer to get new ones...$255 for all of them. And they said get aftermarket lugs. So I got a set of solid lug nuts from Z1 Motorsports for $88.
What rotors are you guys going with? I warped a power stop rear rotor. Anything better out there?
Old Apr 10, 2022 | 04:39 AM
Les7311's Avatar
eBay brakemotive drilled and slotted ( disclaimer: Am not paid for this).
rotors most likely warped because you over torqued them
Old Apr 10, 2022 | 10:51 AM
LtLeary's Avatar
PowerStop is a reputable brand, although I guess it is possible that ypu got a bad one, or improper install, or even a hanging calber/pad. I dont use my brakes that much as most of my driving is highway so I really cant comment on what is better as I run non slotted or drilled rotors.
Old Apr 10, 2022 | 10:57 AM
Bificus99's Avatar
Note likely, I had my torque wrench checked to a new one. Its still accurate. See some good info on the brakemotive parts.
Old Apr 10, 2022 | 12:48 PM
LtLeary's Avatar
Old Apr 11, 2022 | 11:39 PM
User1's Avatar
Brembo blanks all the way baby.
Old Apr 16, 2022 | 06:43 PM
Maxgig's Avatar
+1 on the brakemotive rotors, I have them on my Max and love them. I even put them on my F150, they are great and the cost is very reasonable.
Old Apr 17, 2022 | 06:37 AM
RickSmith's Avatar
Here is my 2016 Maxima lug nut problem and solution.Nissan OEM wheel lug nuts are two piece, these aftermarket nuts are one piece.
​​​​​​https://maxima.org/forums/8th-genera...-lug-nuts.html
Walmart.com also sells the Dorman 611-294 lug nuts.
Old Apr 17, 2022 | 08:18 AM
Bificus99's Avatar
Good info!
Old Apr 29, 2022 | 07:13 AM
LarryJa's Avatar
I put drilled & slotted Centric (3500 grade material) on my 2014 Max. I got cheaper ones 1st, & they warped in short order. The Centric discs perform well.
Buy quality, especially brake parts.
jamaxin97
35
Feb 6, 2007 10:28 PM
Tapio
Mar 28, 2003 11:41 PM
phat99
Dec 9, 2001 01:33 PM
maxman2k
Nov 29, 2001 04:21 AM
amixam69
May 10, 2001 08:39 AM
