CVT noise or what?
Old May 22, 2022 | 05:24 PM
Bificus99's Avatar
CVT noise or what?
Been doing a lot of travel and I have been getting a noise from the cvt on highway passing maneuvers. Whine or a Rrrrr sound. Now I have it all the time, even in park revving I get that sound. I think my VVT solenoids are done as well.
Old May 22, 2022 | 08:06 PM
Les7311's Avatar
Gggrrrrr. I am so trying hard to remember the part. Stealership don’t sell it.
had same problem, bought the part on Amazon for About $35.
dropped the Tran pan, plus filter and that part sits behind it.
it did correct the whine, but too late for keeping Tran at 250k miles.
in my post about Dec 21… searching
Old May 22, 2022 | 08:09 PM
Les7311's Avatar
Stepper motor bad. Check Amazon
Old May 23, 2022 | 03:01 AM
TDGrant's Avatar
Change out your CVT fluid and replace the CVT filter. There is probably a restriction in the filter.
Old May 23, 2022 | 04:16 AM
Les7311's Avatar
heeyyyyy. I agree.
I removed the filter and it was soooooooo clogged. So I sprayed it down with brake cleaner - the filter after dropping the Tran pan
scratch the stepper motor, clean the filter. 🤛🏿🤛🏿
Old May 23, 2022 | 04:26 AM
TDGrant's Avatar
I hear ya, Les. I had to argue with the parts manager at the Dealership about ordering the external CVT filter. They said they have never replaced one, and that makes sense; they do not typically deal with 10+ year old cars.
I had that metal on metal whine, but only in manual mode, and above 4500 RPM, so I figured there was a slight restriction in the lubricating system of the CVT. Easiest and cheapest action was to replace fluid and external filter, which I did; no more CVT whine.
I do the filter and fluid every 30k. My car now has 180,000 miles on it and the CVT is fine.
Old May 23, 2022 | 04:33 AM
Les7311's Avatar
and since our Max is temperamental, the external and internal filter could be the cause. I flushed the external several years
and correct, stealership don’t recommend new filter… $5 brake cleaner works…
Old May 23, 2022 | 07:01 AM
Bificus99's Avatar
Thanks everyone.
Old May 23, 2022 | 09:38 AM
Les7311's Avatar
Thanks everyone.
come back and update us..
Old May 25, 2022 | 06:58 AM
Bificus99's Avatar
Ordered gaskets and filters from rock auto and they are backordered or stupid expensivve to ship and both. $320 shipping to arrive by Friday. WTF?
Old May 25, 2022 | 07:02 AM
TDGrant's Avatar
What did you order?
Old May 25, 2022 | 07:41 AM
Bificus99's Avatar
Gasket, genuine nissan external filter and a 3rd party internal filter to compare with. They don't have the gasket.So Ill call the dealer today.
Old May 25, 2022 | 08:34 AM
TDGrant's Avatar
And that's $320?
Old May 25, 2022 | 08:55 AM
Bificus99's Avatar
And that's $320?
That was just shipping!!!
I called the local nissan dealer and got a gasket and NS2 fluid. $140 all in.
Old May 25, 2022 | 09:03 AM
TDGrant's Avatar
Ah, I imagine that is a database issue at RockAuto, not the actual cost, though since the database is messed up, that is what you would have paid if you had placed an order.
I used to get my engine-air-filter from them. I went on last month and it says I had to order a package of 16 filters with each filter costing $32 each...wtf; and it is still like that. Like I am going to order $500 worth of air filters for my car. I called customer support but there was nothing they could do, so I just ordered it from the dealership.
I guess ya just gotta keep you eyes open...
Old May 25, 2022 | 02:50 PM
mccgavin99's Avatar
growling noise???
I bought my 2016 Nissan Maxima SR like 6 months ago with 127,000 on it 1 owner no accident's and fishbowl (no tint) and not a scratch dent or curb damage the trans started juddering out of nowhere and the car died on highway it always made a growling noise lightly acculturing form a stop to 30 mph then when i replaced the trans at nissan the sound went away when i replaced it but it came back after a few weeks and my gas mileage shot down like it was 32 mph on the highway now the most i can get is like 25.2 idk what it is Do they move some parts from the old CVT to the new one
Old May 25, 2022 | 03:04 PM
TDGrant's Avatar
They do stuff as cheaply as possible, so they probably did some crossover of parts. I would check the external filter. Look at the earlier post to see what it look like. If it looks like it has 120k on it, then it does. if it is old, then change it out.
Old May 25, 2022 | 03:56 PM
Les7311's Avatar
beleive this one
brake cleaner ( as I said before). And spay them down.
that internal gasket most likely look like your house air filter and more. Imaghine the fluid trying to shift through that mesh.
try that first before you waste $325!!!!
Old May 25, 2022 | 03:58 PM
Les7311's Avatar
TD. I pulled the external and used brake cleaner and that took care of cleaning.
Old May 25, 2022 | 04:02 PM
TDGrant's Avatar
That is an option.
Here is what they look like cut open - https://maxima.org/forums/7th-genera...ry-solved.html
Old May 25, 2022 | 04:04 PM
Bificus99's Avatar
Just to be clear Rock auto shipping is the issue, The parts were reasonably priced, $8 for the internal filter $35 for the gasket and $35 for the external filter. $325 for shipping. Then they said they were out of stock on the gasket after all that. Not happy with my last couple of transactions with RA.
Old May 25, 2022 | 04:21 PM
Les7311's Avatar
I will never do business with them (again)!!!!
Every 30k miles, I drain the Tran fluid.
original tran lasted 256k miles until the tran started to slip. Limped car 145 miles to uncle shop and transplanted a 89k miles Tran
uncle said his shop sees our Gen Nissans coming to his shop almost daily with Tran problems/replacing and under 110k miles…
Old May 28, 2022 | 06:13 PM
Bificus99's Avatar
Ok dropped pan, good amount of sludge in and around the magnets mostly and light layer of sludge on the pan. Removed filter and flushed half a can of brake cleaner in it til it came out clear.. It was pretty grey and there were 5 tiny strands of metal on that fine screen. I did the same on the external til the brake cleaner was almost clear. Fluid was pretty beat. CVT appears fine but will know more when I drive it a bit more. Surprised Nissan does not do this or the external filter as maintenance. The #$%^ they told me at the dealer is so wrong. I was trying to educate the service adviser but they are following a script. I gave up.
BTW do not buy the raybestos filter on Rock Auto its not OEM spec, It looks like a window screen, the OEM one looks like a screen printing screen with a fine mesh..
Old May 28, 2022 | 07:23 PM
Les7311's Avatar
just keep your 30k miles drain and fill and read out 1/4mil miles….unless you go beat up every red light drag….
update us…
Old Jun 8, 2022 | 04:38 PM
Bificus99's Avatar
Ok noise is 90% gone and you have to tilt your head to hear it. Drives real smooth. I'll take it.
Old Jun 8, 2022 | 04:55 PM
Les7311's Avatar
remind us: did you clean/replace the inside filter?
Old Jun 8, 2022 | 05:16 PM
Bificus99's Avatar
Yes I hosed both internal and external with a full can of brake kleen and filled it back up with NS2. Noise is faint.
Old Jun 8, 2022 | 05:18 PM
Maxgig's Avatar
Glad you got it fixed cheaply. I replaced my CVT filter at 150k miles, in Apr of 2019. I bought the filter from Fenton Nissan and I only paid $17 for it but that was in 2019. I did a quick search online and now they cost $50 or more. I'm due for my next CVT fluid change in 20k miles, (I change it every 50K).
Old Jun 8, 2022 | 06:55 PM
Les7311's Avatar
most excellent!!
Old Jul 5, 2022 | 02:51 PM
Bificus99's Avatar
Its baaack. !@!#$
Old Jul 5, 2022 | 02:53 PM
TDGrant's Avatar
Its baaack. !@!#$
Replace your external filter.
Old Jul 5, 2022 | 03:52 PM
Bificus99's Avatar
Roger that.
Old Jul 5, 2022 | 03:56 PM
TDGrant's Avatar
Roger that.
When you pull that sucker off and replace it, you'll need some CVT fluid to top it back up. Good luck.
Old Jul 6, 2022 | 05:48 PM
Bificus99's Avatar
Done, getting too good at this. 30 minutes, no jack, tire on. Now wait and see.
Old Jul 6, 2022 | 06:25 PM
Les7311's Avatar
Bnaji
Jan 26, 2018 10:27 PM
Dayray
Jun 14, 2016 07:22 AM
maxima 2012
Nov 8, 2014 03:43 PM
MAXMEL44
Sep 5, 2013 04:29 PM
caz41
Oct 26, 2001 09:41 PM
