Hot Girl In 5spd Max!
Old Feb 8, 2002 | 08:50 AM
skeelo34's Avatar
not! Anyways question for you 5spd guys, when you have the car on can you push the stick into a gear without pressing the clutch? I thought it would try to grind gears, but on mine it wont do anything, jus stays in netural, whether i press the clutch or not, btu when the car is off i can easily play with the gears. Btw i just did the 5spd conversion.
Old Feb 8, 2002 | 09:00 AM
skeelo34's Avatar
Re: Hot Girl In 5spd Max!
damn and i thought sex sells.....
Old Feb 8, 2002 | 09:02 AM
95emeraldgxe's Avatar
nah - u gotta press da clutch when the car is on........it should be the same even though u had the conversion done
Old Feb 8, 2002 | 09:05 AM
jargoone's Avatar
From a stop, no. While you're moving, yes, if you know what you're doing. But since you're asking this question, you probably don't, so don't try it.
Old Feb 8, 2002 | 09:10 AM
AznStevie's Avatar
do you have fluid in the tranny??? 0_o you better! leave your car running for a while and let the fluid circulate...and see if that helps
Old Feb 8, 2002 | 09:15 AM
skeelo34's Avatar
Plenty of fluid, I let it warm up. Also i didnt know taht the manual tranny doesnt connect to the radiator to cool the fluid.....unlike the automatic. Does anyone have a picture of where the hydraulic lines run for the clutch? I didnt know where to mount them.
Old Feb 8, 2002 | 09:16 AM
JdawgX's Avatar
Re: Re: Hot Girl In 5spd Max!
What he's saying is that you can math the rpms and shift without using the clutch after you've started moving. Most race cars shift this way. But they also have gearboxes designed to take the abuse, they replace them after every race, and they know how to shift. They also have straight cut gears. But shifting like this, you shorten the life of your tranny A LOT!
Old Feb 8, 2002 | 09:31 AM
skeelo34's Avatar
Re: Re: Re: Hot Girl In 5spd Max!
So there is absolutely no way to throw it into first gear from a stop in neutral without pressing the clutch? my friend is telling me that it should go to first and the car would stall, so i dont who's right. then again he doesnt have a maxima 5spd........
Old Feb 8, 2002 | 09:52 AM
meccanoble's Avatar
Sports Button FTW
YOOOO, how much did you pay for conversion, pieces, installation and all cause I want to do it but i'm afraid of the price...3 g's is a lot of money, it may be worth it but i'm not trying to spend that kind of dough...if it was a 1,000 dollars or under, i'm getting it
Old Feb 8, 2002 | 09:55 AM
sarmast's Avatar
There is a hot girl in my 5-sp max, when my wife is driving it.
delio's Avatar
Re: Re: Re: Re: Hot Girl In 5spd Max!
No You should not be able to do that with your car... you should be able to step on the clutch, put it in first, and then let off the clutch and the car should stall... unless you can somehow get the car moving... But if you let up off the clutck quickly enough it should stall.
Old Feb 8, 2002 | 09:59 AM
JdawgX's Avatar
Re: Re: Re: Re: Re: Hot Girl In 5spd Max!
Does anyone read what the question is before posting??? He wants to know if you can put it into first WITHOUT putting the clutch in. I suppose if you pressed hard enough you MAY be able to. But the tranny WILL hate you, and you'll have a couple of pounds of metal shavings to drain out of the tranny from all of the grinding. DON'T DO IT!
Old Feb 8, 2002 | 10:13 AM
meccanoble's Avatar
Sports Button FTW
that's virtually impossible...that's why it's called STICK...what you CAN DO is double ****...well, that's what they were doing in Fast and the Furious...an automatic might speed past you for the first 2 seconds due to you having to get your speed up, but if you double shift correctly, you'll smoke him like a bag of weed
Old Feb 8, 2002 | 10:51 AM
skeelo34's Avatar
Re: Re: Re: Re: Re: Re: Hot Girl In 5spd Max!
THANK YOU!
Old Feb 8, 2002 | 11:38 AM
Lime's Avatar
what is a pressure plate?
edit: for those of you who didn't get it, that was sarcasm up there.
Old Feb 8, 2002 | 11:54 AM
jdmmax's Avatar
hey skeelo did you do the swap youself or did a shop do it for you.
how difficult was it if you did do it yourself?
Old Feb 8, 2002 | 12:06 PM
YDRSBTR's Avatar
What's so hard about just pushing the bloody clutch pedal in...? Seriously, why are you trying to do without that trivial little step (no pun intended)?
Old Feb 8, 2002 | 12:25 PM
skeelo34's Avatar
I want to know if there is something wrong with my transmission or not. I wanted to know if you could do that. I just did a 5spd swap so I don’t know what is normal and what isn’t. I bled the system of air but my clutch still does not want to pop back up after pushing it in. It also loses pressure when the car is turned on as opposed to off (the pedal is a lot stiffer and pops back when the car is off). Do you think if I went through all of this I would be asking a question that might sound stupid, when it really isn’t?
Old Feb 8, 2002 | 12:27 PM
JdawgX's Avatar
He didn't aim that twords you. There are some other people whoring up this post with stupid questions about shifting without the clutch. That's what he was responding to. If I were you, I'd take the car into a local mechanic and have him take a look at it. Most people around here have no clue how to work on the car that Mommy and Daddy gave them. I wish you luck in getting it fixed though. And good job having the ***** to actually go through with something, not just talk about it.
Old Feb 8, 2002 | 12:29 PM
YDRSBTR's Avatar
See, all that is pretty key information you should have included from the start. Simply asking if you can shift without the clutch doesn't give us enough information to go by.
So it's bleeding pressure when the car is on, but not when it's off...?
Old Feb 8, 2002 | 12:32 PM
jargoone's Avatar
I did. Did you?
I saw nothing about first gear there.
sarmast's Avatar
Its like this plate thats under pressure.
Old Feb 8, 2002 | 12:38 PM
JdawgX's Avatar
I did. Did you?
You must read further on Danial son
Old Feb 8, 2002 | 12:53 PM
skeelo34's Avatar
OMG am I speaking another language????? The question was simply can I shift the tranny without pressing the clutch from neutral while the car is stopped. It is just that simple. If someone answered me “yes,” then I would know there is something wrong with my transmission, or not the clutch pedal, since I can’t shift in neutral while I’m stopped with the engine on. If they told me you cannot shift, then I would have to conclude that it is the clutch pedal not working right.
Old Feb 8, 2002 | 01:01 PM
JdawgX's Avatar
Read my above posts. I'm pretty sure I answered you already. If you still need something then please be more specific and I'll answer what I can.
Old Feb 8, 2002 | 01:13 PM
YDRSBTR's Avatar
Slow down there, Skippy. Relax. You got your answer. Fuhgeddaboutit.
Old Feb 8, 2002 | 01:51 PM
skeelo34's Avatar
Thank you all for the answers. I get a little frustrated when people don't read but its all good.
Old Feb 8, 2002 | 02:14 PM
sarmast's Avatar
Simple answer: No. You can't match the engine speed (idle RPM or whatever you have gassed it to) and the tranny rpm (0). It is possible to shift without the clutch while moving, though not recommended because you have to match rpms very closely or damage your tranny. If you try forcing it into 1st from a stop without the clutch, you'll just hear grinding until your tranny dies or your engine stalls and you clunk forward a few inches/feet.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
