Hot Girl In 5spd Max!
not! Anyways question for you 5spd guys, when you have the car on can you push the stick into a gear without pressing the clutch? I thought it would try to grind gears, but on mine it wont do anything, jus stays in netural, whether i press the clutch or not, btu when the car is off i can easily play with the gears. Btw i just did the 5spd conversion.
Re: Hot Girl In 5spd Max!
Originally posted by AznStevie
do you have fluid in the tranny??? 0_o you better! leave your car running for a while and let the fluid circulate...and see if that helps
Re: Re: Hot Girl In 5spd Max!
Originally posted by jargoone
From a stop, no. While you're moving, yes, if you know what you're doing. But since you're asking this question, you probably don't, so don't try it.
Re: Re: Re: Hot Girl In 5spd Max!
Originally posted by JdawgX
What he's saying is that you can math the rpms and shift without using the clutch after you've started moving. Most race cars shift this way. But they also have gearboxes designed to take the abuse, they replace them after every race, and they know how to shift. They also have straight cut gears. But shifting like this, you shorten the life of your tranny A LOT!
Re: Re: Re: Re: Hot Girl In 5spd Max!
So there is absolutely no way to throw it into first gear from a stop in neutral without pressing the clutch? my friend is telling me that it should go to first and the car would stall, so i dont who's right. then again he doesnt have a maxima 5spd........
Re: Re: Re: Re: Re: Hot Girl In 5spd Max!
Originally posted by delio
No You should not be able to do that with your car... you should be able to step on the clutch, put it in first, and then let off the clutch and the car should stall... unless you can somehow get the car moving... But if you let up off the clutck quickly enough it should stall.
that's virtually impossible...that's why it's called STICK...what you CAN DO is double ****...well, that's what they were doing in Fast and the Furious...an automatic might speed past you for the first 2 seconds due to you having to get your speed up, but if you double shift correctly, you'll smoke him like a bag of weed
Re: Re: Re: Re: Re: Re: Hot Girl In 5spd Max!
Does anyone read what the question is before posting??? He wants to know if you can put it into first WITHOUT putting the clutch in. I suppose if you pressed hard enough you MAY be able to. But the tranny WILL hate you, and you'll have a couple of pounds of metal shavings to drain out of the tranny from all of the grinding. DON'T DO IT!
THANK YOU!
Originally posted by YDRSBTR
What's so hard about just pushing the bloody clutch pedal in...? Seriously, why are you trying to do without that trivial little step (no pun intended)?
I want to know if there is something wrong with my transmission or not. I wanted to know if you could do that. I just did a 5spd swap so I don’t know what is normal and what isn’t. I bled the system of air but my clutch still does not want to pop back up after pushing it in. It also loses pressure when the car is turned on as opposed to off (the pedal is a lot stiffer and pops back when the car is off). Do you think if I went through all of this I would be asking a question that might sound stupid, when it really isn’t?
See, all that is pretty key information you should have included from the start. Simply asking if you can shift without the clutch doesn't give us enough information to go by.
So it's bleeding pressure when the car is on, but not when it's off...?
I did. Did you?
I saw nothing about first gear there.
I did. Did you?
You must read further on Danial son
OMG am I speaking another language????? The question was simply can I shift the tranny without pressing the clutch from neutral while the car is stopped. It is just that simple. If someone answered me “yes,” then I would know there is something wrong with my transmission, or not the clutch pedal, since I can’t shift in neutral while I’m stopped with the engine on. If they told me you cannot shift, then I would have to conclude that it is the clutch pedal not working right.
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
RWCreative
09-21-2015 11:01 AM
