Temperature gauge is always at cold (minimum)
Old Nov 21, 2023 | 10:59 AM
steve98's Avatar
The temperature gauge in my 2008 Maxima (3.5L engine) is always at cold. I used the OBD-II and the real time ECT gave normal reading. How should I fix it? Thank you.
Old Nov 21, 2023 | 07:03 PM
chrome91's Avatar
If you have heat and OBDII gives you the correct reading, it's either your gauge cluster, the temperature sensor that gives the reading to the cluster, or the wiring from the sensor to the cluster. Most likely is the sensor, but do a quick visual check of the wiring and make sure the connector is fully plugged into the sensor as well
Old Nov 22, 2023 | 10:51 PM
steve98's Avatar
My car only has 1 sensor. I didn't see any broken cable. So I think it likely to be the gauge cluster but I don't want to waste money on replacing that for just the coolant temperature gauge.
Shasta Conner
Feb 19, 2021 07:31 PM
reggaeboyz
Feb 16, 2006 11:55 AM
JoySoCute
Nov 27, 2004 04:58 AM
fatboyp
Jan 28, 2003 02:11 PM
jlee4
Apr 1, 2002 09:44 PM
