2005 Nissan Maxima No spark
Old Nov 24, 2023 | 09:17 AM
JCMaxima05's Avatar
So my 05 Maxima isn't getting any spark. before this issue arose I was driving around after a fresh oil change and a full tank of gas. It snows here so I ended up getting stuck into a ditch. The driver's side was on the flat road while the passenger side was stuck in about a foot in a half of snow. Trying to get out I kept shifting into drive/reverse which then got me into a spot where the car would no longer move. The car was still running but then it started to bog down and eventually die. I tried to start it and all it would do was just crank. Eventually that led to the battery now dying etc.
I did a few tests myself. got some starter fluid to eliminate if it was a fuel issue. It still didn't start. Pulled a plug and tested if I was getting a spark which it's not. I'm going to take a better look at the camshaft sensors etc but I'm just not sure what's going on. Does anybody have any other things i could check? I have an appointment with a shop but that's not until December 19th
Old Nov 24, 2023 | 08:07 PM
chrome91's Avatar
If you have a scanner with live data, might be worth seeing if it's getting RPM when being turned over
Old Nov 24, 2023 | 09:08 PM
JCMaxima05's Avatar
it's at a shop now. just figure did leave it up to them since they got better equipment than I do. Once they tell me whats wrong ill fix it myself
Old Nov 25, 2023 | 08:27 AM
chrome91's Avatar
Sometimes it's the easiest lol lmk what it is im curious, im guessing crank/cam sensor issue
Old Dec 2, 2023 | 10:36 AM
JCMaxima05's Avatar
From the mechanics notes. Basically they are gathering that it skipped time. Each can shaft was at 127 degrees advanced.
compression was 25lbs less in bank 2 vs bank 1
they also checked valves and bank 1 coils. They seen some damage on cylinder 1 and 3 due to valve clearance issue.
at this point I’m marking it off as a loss. I was going to possibly have the do a timing chain job as I know it needed it. But they said it wouldent be worth it. And that might not even really fix the issues. Maybe I’ll call around.
devon89maxima
Jan 22, 2023 06:12 PM
johnsm42
Feb 4, 2013 10:39 AM
tallica62
31
Oct 20, 2010 06:29 AM
MaxFanatik
Aug 31, 2007 03:30 PM
305/85r16
Dec 28, 2004 01:44 PM
