after market wheel center cap issue
Old Nov 22, 2024 | 05:05 PM
uptownsamcv's Avatar
I ended up getting a new set of aftermarket wheels since the body shop that painted my car was taking way too long to paint my 350Z touring wheels and every other place I went to wanted way too much. only issue I'm having now is the center cap on the new wheels won't go on. the threads on the CV axle poke out a little too much and the same in the rear with the cap over the hub nut. has anyone else with aftermarket wheels had the same issue?
for the fronts I am thinking about cutting a few threads off the cv axle and for the rear i was thinking of either running with no hub nut cover or putting a mallet to it.
Old Nov 23, 2024 | 05:48 PM
Slamrod's Avatar
Any reason you wouldnt just run wheel spacers? Would solve your problem and has aesthetic appeal to boot.
Old Nov 23, 2024 | 10:11 PM
the offset is perfect, no scraping in the rear like when I had the 350Z touring wheels.
Old Nov 24, 2024 | 09:42 AM
westdude's Avatar
are these stock wheel caps on after market wheels? Are those wheels "RAYS" ?
https://www.ebay.com/itm/304677371245
Old Nov 24, 2024 | 12:00 PM
it's the center cap that came with the aftermarket wheels...
Old Nov 24, 2024 | 05:14 PM
westdude's Avatar
I editted my post just as you replied
Old Nov 24, 2024 | 07:38 PM
the wheels are Katana Racing KR08
Old Nov 25, 2024 | 09:10 AM
so on the rear I ended up removing the dust cap from the hub. the bearing appears to be sealed so it should be fine.
on the front I cut all the outer threads past the CV axle nut, the nut still comes off and goes back on fine.
Old Nov 25, 2024 | 10:33 AM
RA030726's Avatar
I'm nutty for Nissans
Cuts off cotter pin.
Better slap it and say, "It's not going anywhere."
Old Nov 25, 2024 | 11:13 AM
never used a cotter pin. I just torqued them to 160 ft lbs with some thread lock and haven't had any issues in 12 years...
bmanbmv
Oct 1, 2009 05:10 PM
Gian13
Nov 11, 2008 05:28 PM
PandaXpress
Mar 27, 2007 07:13 AM
nearthisbridge
Mar 23, 2007 12:16 PM
bb0ys
Apr 28, 2003 05:36 PM
