Most reliable Maxima's
Old Mar 8, 2025 | 05:17 PM
maxipriest777's Avatar
I can across this AI generated
oF the most reliable Maxima's.
Wanted to hear opinions.
Old May 1, 2025 | 07:10 PM
oughtsix's Avatar
2003 (5th gen) Maxima with 268K. Repairs:
Valve cover gasket
Front bearings replaced - 1 bad
Rear bearings replaced - 1 bad
Radiator Replaced - Bad
Plugs replaced - Preventative
All coils replaced - Preventative, while I was there I might as well replace then (Hitachi)
Fuel injectors - One was bad. Figured I should replace all of the injectors while I was there.
Alternator - bad
Power steering return hose - leaking
Rear struts.
Radio / head unit - easier to replace than I thought. My daughter LOVES the new ATOTO Head unit!
For 268K / 23 year old car I think this is quite good. I bought my early 2003 used in 2004. I used it to drive my new born daughter home from the hospital. It is her car now. It sat for 3 years after I was done with it before she was old enough to drive (Sitting stationary and ignored is hard on a car).
I had kind of wished I waited for the 6th gen after they came out. I loved the idea of the CVT! Reading through this forum I am MUCH better off with my 2003 than if I had bought an early CVT.
Old May 4, 2025 | 06:46 PM
Roblee22's Avatar
I’ve had several Maximas over the years, but I must say I love my current 07 SL that I have owned for nearly 3 years. So far I’ve replaced the rear wheel bearings, alternator, battery, front struts, both camshaft sensors, CVT trans filter plus 4 drain and fills on the CVT fluid. I have brand new control arms in the trunk, those are going on Thursday. Also just installed a Cold air intake. Also replaced the radiator. The throttle is more responsive with cold air intake and the motor is a little louder aswell, but I cant say if it picked up a noticeable amount of power as I haven’t been WOT in awhile due to me needing to replace my control arms.
Old May 4, 2025 | 06:48 PM
Roblee22's Avatar
And actually, the early CVTS in the 6.5th gen Maximas are more reliable than the ones in the 7th gen Maximas, I have 160k miles on mines so far. Its mostly the CVTs in the 4 cylinder cars that fail more often
20th maxstyle
May 5, 2002 06:01 AM
