2016 Nissan Maxima Gear/Acceleration Issues?
Old Apr 15, 2025 | 05:40 PM
jdsimons2's Avatar
Hi!
I have a 2016 Nissan Maxima with about 195k miles. Here's what I'm experiencing:
- Car jolting/jerking on acceleration. As long as I'm not shifting gears it seems to be okay mostly. It's most noticeable when getting up to speed, going uphill... times when you gotta accelerate and "kick it into high gear" lol
- Accelerator is sometimes unresponsive
- Car will rev up to 3000RPM when shifting gears and then come back down
- General instability in speed/acceleration.
These issues began just after something weird happened: My car doors wouldn't unlock - and the car battery had died. I charged the battery back up, things worked as normal, then a few days later these issues began. Also, back in 2020, I was experiencing similar issues and had the alternator replaced back in 2020. In addition to acceleration issues, I completely lost power and the car died, and needed it towed to a repair shop. It got repaired with an aftermarket alternator, which I've read is not good. I do believe I've had the transmission fluid flushed one time.
I took it into a repair shop and they said I need a full transmission rebuild at $6000. Here's part of their transmission report:
"Using scanner checked for codes found code for transmission JUDD. Test drove vehicle and watched live data checked for misfires none. Checked MAF readings and readings were good, checked o2 readings and readings were good. Checked operation of both throttle body and accelerator sensors and both read good. While test driving monitored transmission temp and found transmission temp to be high, when driving trans vehicle was jerking due to trans slipping. When trans slipping rpm would jump to 3k and then trans would grab and bring rpm down."
I googled code "JUDD" and couldn't find anything on that.
Also when testing the battery:
"Tested battery and battery tested good but terminals are heavily corroded and appears battery is leaking. Tested charging systems and stayed around 14 volts. Tested for amp draw and no amp draw.tech rec replacing battery and cleaning terminals"
Am I SOL and I need a full tranny rebuild? He let me know that because of these symptoms, the car is a ticking time bomb and the tranny will fail any time. Because my issues are similar - do we think it's the alternator? Is it worth purchasing an OEM Alternator and putting that in? The difference between a $1000 repair and $6000 repair is significant - especially if the tranny isn't even the real issue.
Any advice would be much appreciated. Thank you!
Sportscars
Jan 15, 2025 10:07 AM
Torie76
Jul 19, 2024 08:31 AM
AustinBorst
Mar 24, 2024 04:45 AM
ulregon
Jul 20, 2020 11:04 AM
markeldeiry
Jun 7, 2014 10:01 PM
