Cvt problems
Cvt problems
Hi all I have a 2014 Nissan Maxima s and it has the CVT. Before I got the car apparently it had a blown head gasket that got fixed due to the car overheating. Now the transmission feels like its slipping but the transmission fluid smells burnt and has never been changed in 107k miles. Do you all think I should just change the fluid and the filter and it would fix it or could it be the shift solenoid. It still shifts smooth but when accelerating it feels jumpy. Thanks in advance
Try This
Replace the fluids.
Install a heavy duty transmission cooler
Also keep in mind that CVT transmissions
Don't actually shift.
But. Anyways , the transmission cooler
Is the most important component
In this chain of responsibility
Question
Is there a way to check the valve body
Check Valve Body
No codes ?
level on the dip stick is where it's supposed to be.
Then. The problem is mechanical.
The only thing you can do at this point is
Replace the fluid and filter, and hope for the best.
Anwar
Sep 14, 2022 04:12 PM
