WSP announces Radial Arms
Late this week Dallas will be installing a set of radial arms on our 96 SE. We will be posting PICs a short time later. These arms have a reputation of significantly reducing wheel hop, aiding in quick acceleration by increasing traction. With these you should see decreased 1/4 mile times by decreasing wheel spin.We think we can offer them for a reasonable price. I know we will be looking for a few people to try the first few sets. If you are active at the track, you might want to send an e-mail. I know we will want to test each generation. Will keep every one updated.
Dan WSP
Dan WSP
Re: WSP announces Radial Arms
Dan WSP
Dan WSP
Thanks!
Ahhhh yes, praise the lord for this one. If these do what they say they do, I'll be all for it.
For the others who dont know what these do, http://www.overboost.com/story.asp?id=460 is a link.
Very cool product
It's easy to install too. Probably as easy as a rear sway bar. I bet you guys will move alot more these than the sub frame connectors. Since no welding will be needed so the average DIY can do this. Are the subframe connectors ready for the 4th gen yet?
Originally posted by Bman
Wow, are these guys great or what?
Kepp up the excellent work WSP!
Radial arms
ericdwong thanks for the link. I forgot to post it last night. BTW, these are gonna be a bolt on application. So the average do-it-yourselfer can do it in his garage.Also, this mod was an idea that came from an idea sent to us by a maxima.org member. Thanks!
Dan WSP
Dan WSP
Re: Radial arms
Dan WSP
Dan WSP
Re: Radial arms
Dan WSP
Dan WSP
Originally posted by SuDZ
Will you be able to install it with a rar sway bar? Just wondering if I get my rear sway bar if I can use this still. Dont know if they would get in the way of each other.
SuDZ
SuDZ
SuDZ
SuDZ
This could provide a nice (and more effective) alternative to new engine mounts. Since everybody who gets the mounts installed reports added vibration due to the stiffer bushings, it would be nice to reduce wheel hop without increasing vibration.
I'm interested. WarpSpeed seems to be doing all the right things.
The Radial Arms look great especially for the reduction in wheel hop. I considered the engine mounts but this solution is even better
Does anyone have access to the videos for that overboost.com article? I'd be interested in seeing the difference with and without the radial arms. I've never spent much time at overboost but maybe I should start.
-hype
Does anyone have access to the videos for that overboost.com article? I'd be interested in seeing the difference with and without the radial arms. I've never spent much time at overboost but maybe I should start.-hype
Originally posted by guido_sst
I don't see how they would, radius arms go up front and the RSB goes in the back.
SuDZ
Good shot Dan, let me know some prices and everything, I might give these a test if you give me some details on what that involves exactly, sounds like a nice little tool for less wheel hop keep us updated
Will it just stop wheel hop or will it also improve handling any?
Another question is Other things that have been known to stop wheelhop like motor mounts have resulted in shaking of the car... is that going to happen here too?
SuDZ
SuDZ
Dan:
How much will they cost?
When will they be ready ?
How much wheel hop do you hope to eliminate ?
Sorry but that link makes my comp freeze, so I couldnt read it. Also, Is this mod effective enough to say it can make our max's act as if they were RWD ?
Originally posted by Craig Mack
Dan:
Dan:
-hype
http://hybrid.honda-perf.org/tech/z10.html and http://www.z10eng.com/index2.htm will give more information on the concept and theory behind the radius arms. Theoretically, the arms should also improve handling, as they will stablize the lower control arms from fore/aft movement and lateral movement being as the bracing bars will be at an angle, while still allowing up and down movement of the control arms.
However the main purpose should be to eliminate wheel hop, or all the front/back slopping motions and drivetrain slack. Hopefully they will not be too expensive, but this is one of the mods I will definately do, no matter what the cost (within reason).
Hmmm my old Datsun 510 already had these. hehe.
Last of the modern Nissans to have these were the Infiniti M30s.
Nice to see these come back. Especially when they used the existing mounts to do it all. Nice.
I've got Cattman/PR engine mounts on the car already. Would adding the radius arms constitute overkill? Please advise. By the way, I'm in Memphis, and I'll be going to the Memphis MotorSports Park on a regular basis this year. I "might could" test those radius arms on my '95 Maxima SE 5-spd...
Very interesting articles. If the WSP Radial Arms can be made to clear 18x8 rims and not require drilling then this mod would probably become more popular than the FSTB, RSTB, or maybe even the RSB
The only negative I noticed from the articles is the change in toe due to the preload. Would this extra preload stress any components at all? I'm not all that familiar with our control arms and such.
-hype
The only negative I noticed from the articles is the change in toe due to the preload. Would this extra preload stress any components at all? I'm not all that familiar with our control arms and such.-hype
I would personally like to try out the mounts on my car, cause the Quaife differential for me added alot of wheel hop during the 1-2 shift, and hopping when its raining outside (or in the burnout box). Not many members here have the Quaife installed, who's still running the stock suspension and motor mounts like I am. I was planning to get the energy suspension poly control arm bushing too, but I'm going to hold off now that these are in development.
Originally posted by ericdwong
Hey Bullseye, I have the quaife but got rid of the P/R mounts. Even when I had the mounts, I had significant wheel hop during a 1-2 shift and also in the rain. Do you have this problem? I feel it would not be overkill in traction if you put this on.
Hey Dan couple of questions because I know your email box is probably flooded:
Will they be adjustable?
Will they interfere with the front tires at full lock?
Why do you keep coming out with new parts, I'm broke!?!?!?!
Could you guys possible develope some parts for the 2000 celica?
We are in dire need of performance parts.
I think radial arms would be fantastic for a celica and would sell very well.
check out www.newcelica.org for our large group.
thanks for your consideration,
Kit
Kit
Dan WSP
Dan WSP
Dan, I am concerned about wheel clearance, I have 16x8 50mm offset third gen RX7 rims. They sit very close to my strut perch. I do get some rubbing against the plastic fender liner when turned to full lock. I may want to get a set from you but dont want to have to space out my wheels. Do you think this will be an issue?
Re: Re: WSP announces Radial Arms
Kit
Kit
SuDZ
