Black Smoke at startup with engine hesitation
Does it happen when it's cold or hot? If it's happening when the car is warm, then it's most likely your coolant temp. sensor. There are 2 sensors, one for the gauge and one which the ECU reads. Do a search on here, I know there are a few threads on this. I want to say the sensor closer to the block is the one the ECU uses.
Originally posted by mbb6
Happens when it's cold out and when it has been sitting overnight.
How would i clean my throttle body, thu a mechanic or ???
check out www.motorcate.ca for directions
SuDZ
cannot link to site for some reason
Originally posted by SuDZ
God no. They will way overcharge for this one.
SuDZ
SuDZ
Actually, that was a dig on Bosch plugs. A lot of people have had driveability problems with those - especially Maxima owners.
Anyway, a leaky injector is a distinct possibility. Don't know how mechanically inclined you are, but you could start with some injector cleaner to try to free it up. If that doesn't work you could throw a fuel pressure gauge on the rail and look for a pressure drop after the engine is shut off.
Other than that, it could be a bunch of different things unfortunately.
trungg86
Sep 4, 2015 04:58 AM
