Plastic block behind the pedal? and timing?
Old Feb 15, 2002 | 06:48 AM
Pr1dmx88's Avatar
What is that little plastic block behind the acclereator bedal doing there and will i mess anything up if i take that crap off. and how hard would it be to advance the timing on my 92' gxe. auto.
Old Feb 15, 2002 | 08:12 AM
GreenMaxVE's Avatar
Re: Plastic block behind the pedal? and timing?
Removing that plastic block will not do anything. You are already at WOT when the gas pedal hits it. Removing it may cause you to snap your throttle cable or bend your throttle plate from overturning in the throttle body.
Old Feb 15, 2002 | 10:04 AM
Pr1dmx88's Avatar
Re: Re: Plastic block behind the pedal? and timing?
how d you know this and are you absolutly sure?
Old Feb 15, 2002 | 10:29 AM
whitymax's Avatar
Try it for yourself and find out.
HAHAHAHAHAHA
have fun fixing your cable
Patrick
Old Feb 15, 2002 | 10:31 AM
Chris Gregg's Avatar
Get Off My Lawn
Yes he is sure, as am I. If you want to verify it for yourself, then simply pop the hood and manually move the throttle to WOT (car off of course!), then have a friend press the pedel to the floor and you will see that it stops at about the same place. If if makes you feel better, I personally removed the block behind the pedel and compared the distance the throttle would move, it didn't move any more and I could see the amount of strain on the cables, which is not good. Plus, you'll have that peice of metal sticking out of the floor which would look stupid. Timing: move the crank angle sensor. Of course you need a timing light.
Old Feb 15, 2002 | 01:40 PM
Matt93SE's Avatar
STFU n00b!
Re: Re: Re: Plastic block behind the pedal? and timing?
yes, we're sure. been done before. nothing but problems. if you want to buy a new throttle cable and throttle body, then please do it. if not, then take our advice and leave it be. nissan wasn't dumb when they put it there.
Old Feb 15, 2002 | 01:52 PM
Maximan190's Avatar
yea keep it on...in fact im thinking of adding another piece of plastic or wood or a bigger stopper like that so i cant floor it...ive been too floor-happy lately and my mpg has been sucky
Matt93SE
May 24, 2019 02:58 PM
kjlouis
Nov 24, 2018 06:09 AM
Stagnet04
Aug 16, 2015 11:15 PM
Balkins
Aug 12, 2015 06:39 AM
