Plastic block behind the pedal? and timing?
What is that little plastic block behind the acclereator bedal doing there and will i mess anything up if i take that crap off. and how hard would it be to advance the timing on my 92' gxe. auto.
Re: Plastic block behind the pedal? and timing?
Removing that plastic block will not do anything. You are already at WOT when the gas pedal hits it. Removing it may cause you to snap your throttle cable or bend your throttle plate from overturning in the throttle body.
Re: Re: Plastic block behind the pedal? and timing?
Yes he is sure, as am I. If you want to verify it for yourself, then simply pop the hood and manually move the throttle to WOT (car off of course!), then have a friend press the pedel to the floor and you will see that it stops at about the same place. If if makes you feel better, I personally removed the block behind the pedel and compared the distance the throttle would move, it didn't move any more and I could see the amount of strain on the cables, which is not good. Plus, you'll have that peice of metal sticking out of the floor which would look stupid. Timing: move the crank angle sensor. Of course you need a timing light.
Re: Re: Re: Plastic block behind the pedal? and timing?
Originally posted by Pr1dmx88
how d you know this and are you absolutly sure?
kjlouis
11-24-2018 06:09 AM
