2k2 Maxima engine vs. 350z engine
I was at the Chicago Auto Show at took a look at the new 350Z.. From what they were saying it has the same 3.5 engine as the Maxima.. However they said that it is capable of over 280hp.. Is it simply a couple of differences in the computer, if so do you think that Nissan will release some sort of programming to increase the preformance of the 3.5 Maxima engine.. WHAT DO YOU GUYS THINK.. I am still new to this so take it easy.. PLEASE
Re: 2k2 Maxima engine vs. 350z engine
Re: There is no way
Originally posted by Colonel
Nissan is going to let their 4door have the same HP as their sports car. Marketing thing...but also my opinion.
Would be nice to have that capability though....
line up an automatic Z against a maxima and see what happens
It should be interesting to see what kind of aftermarket support the 350Z gets.
Hopefully, between NISMO and the aftermarket some of the parts will be similar enough to swap over to the 2K2.
Originally posted by Jeff92se
From what I see on the engine, the maxima only has the timing control assemblies mounted on the intake cams.
Originally posted by sardarg89
is variable timing on the intake and exhaust not the same thing as the variable intake manifold and variable-capacity muffler?
I believe Jeff is right - the VTC on the VQ35, at least on the Maxima, is only on the Intake valves and varies phase only and not lift.
The variable intake manifold and variable muffler are completely different things. VTC controls valve timing whereas the manifold controls the air supply before the valves and the variable exhaust varies backpressure after the exhaust valves all the way at the end of the exhaust system.
although I know the difference between valve timing (phase/lift) and variable intake manifold/variable capacity exhaust, I was too stupid to realize that he was talking abotu the intake/exhaust valves (when he mentioned timing, it should have been obvious)...
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
BassAddictJ
Aug 4, 2015 11:38 AM
