Question about rotors on a 1999 Maxima
Old Feb 25, 2002 | 11:01 PM
Zagginzeed87t's Avatar
Hello All,
I'am new to this site so excuse me if I'am asking a rather dumb question. I own a 99 Max GLE and I just replaced the front brakes about a week ago. I used discbrake quiet while doing this and my brakes are speaking like hell. I didn't get the rotors turned because I assumed they didn't because of low miles. My question is how do I get the rotors off? I pulled off the whole caliper and the rotor didn't come off so I'm assuming I have to take off the center nut in order to get the rotors off and repacking the bearings when re-installing correct? Am I right or should I knock off the rotor lightly with a hammer? Thanks in advance......
Old Feb 25, 2002 | 11:24 PM
Originally posted by slammed95
The rotors are held on just by the wheels and the lug nuts. They might need a light tap from a hammer, with a thick folded cloth in between of course. By the way since your brakes speak, what do they say?
Perfect newbie introduction. All newbies should learn from this.
Hahahahahahaha!!! Hey thanks alot man, I wuz just about to take it to the shop and let them turn the rotors for me. It's really my girls car and its practically still new (I own a 87turbo Z) and didn't wanna f up anything ya know? I'd rather be safe than sorry, I had thought about tapping on the rotors but got scared and left them alone!!! By the way, brakes are yelling "Turn the ******* rotors you fool!!!"
Old Feb 25, 2002 | 11:57 PM
KWheelzSB's Avatar
Extractor Bolts
There's actually another answer. If the rotor can't be persuaded off the hub with either a rubber mallet or a few light taps from the behind with (use a piece of wood or thickly wadded shop-towel covering the rotor) a hammer, then. . .
With the wheels off, you'll notice there are two threaded bolt holes in the face of the rotor in between the stud bolts, 180 degrees opposite one another. These are for "rotor extractor bolts." Thread two extractor bolts* into the holes evenly and once they thread through until they meet the hub, stop threading them. Now, alternating between the two bolts, count equally distanced turns (1 turn/360 degrees @ a time) on each bolt, alternating between the two until the rotor breaks free of the hub assembly. (Surface corrosion is usually the only thing holding the rotor in place).
Refer to:
Haynes manual
Chapter 9, Page 11
(buy one: www.amazon.com [ISBN# 1 56392 359 9])
*Extractor bolts may be obtained through your local auto parts store or your Nissan dealer. (I got a pair from my dealer - they were nice enough to give them to me, even though I offered to pay for them). If your dealer isn't as kind, they should at least be able to tell you the correct size. Don't quote me, but I think it's an 8mm bolt & I'm not sure of the thread pitch.
Good luck!
P.S: Did you apply the anti-squeal goo to the back of the shim & let it "set-up" for a few minutes before installing the pad? That's important to allow the anti-squeal stuff to do it's job correctly.
Old Feb 26, 2002 | 12:02 AM
spiff56747's Avatar
Re: Question about rotors on a 1999 Maxima
Originally posted by Zagginzeed87t
Hello All,
what kinda pads did you put in? I hope they were not Bendix, cuz you will never get rid of the squeal..
also, this may seem kind of obvious, but the rotors don't usually cause squealing brakes.. usually the main result of warped rotors is a pulsating brake pedal.
Old Feb 26, 2002 | 08:04 AM
iwannabmw's Avatar
Re: Extractor Bolts
Refer to:
Haynes manual
Chapter 9, Page 11
Good luck!
Squirt some Liquid Wrench through those "extractor" holes and then whack the rotor, it will pop right off.
Old Feb 26, 2002 | 08:54 AM
SuDZ's Avatar
Well if ya ever get stuck again let us know. People around here can be very helpfull and answer all kinds of questions you might run into.
SuDZ
03VQMAX
Sep 25, 2015 04:19 PM
Stagnet04
Sep 2, 2015 07:53 AM
MikesChevelle
Aug 10, 2015 10:53 AM
xUNIxPanther
Aug 5, 2015 09:31 AM
RealityCheck
Aug 5, 2015 06:18 AM
