2k SE - anyone haveing this problem??
Old Mar 12, 2002 | 06:35 AM
mike-777's Avatar
On 3 or 4 occasions when I turn the key nothing happens as though there is no electrical connection from the ignition to the starter.
Anyone else have this happen?
After 4 or 5 trys, it does start as though nothing is wrong. A little disconcerning.
Old Mar 12, 2002 | 06:43 AM
Thorzdad's Avatar
Re: 2k SE - anyone haveing this problem??
Are you an automagic or manual?
Old Mar 12, 2002 | 07:55 AM
mike-777's Avatar
My car is an Automagic.
I've tried moving it from part to nuetral - no difference.
Old Mar 12, 2002 | 09:58 AM
Thorzdad's Avatar
I believe automatics are supposed to have a lockout switch that allows ignition only when in park or neutral. Could be that switch is going bad.
Old Mar 12, 2002 | 10:52 AM
TPI Monte SS's Avatar
You should try checking the battery cable connections too. If they are loose, your car will exhibit the same symptoms.
Hope that helps!
Lakersallday24
Nov 7, 2024 07:31 PM
Maxilano
Aug 31, 2015 07:33 PM
Samedi
Aug 13, 2015 04:05 PM
jomax14
Aug 12, 2015 11:49 AM
Bruceharrison
Aug 9, 2015 07:56 AM
