gc coilovers....
Re: gc coilovers....
Originally posted by a33
can anyone tell me about it...
i am about to get it, but i want to know what i have to do to the struts to make it fit...
i currently have the h&r and tokico setup
BTW I think Y2Kev has/had these.
first, i dont hink the car is low enough, for some reason, i still have 4 fingers of gap in the front, the back is ok, and in my opinion, i think the tokico's are too soft, i like the ride to be stiff, cuz i like it when the car doesnt roll to one side when i turn...
I'm on Eibachs and I only have 1 finger gap front, half finger rear... I thought H&Rs went lower than eibachs..BTW.. I heard you have to shave off something to make the GCs fit.. I was thinking of getting GCs myself but still debating whether it's worth the trouble since I'm an everyday driver..
From your earlier and unfortunate visit, You must know NYC roads are the worst. I bottom out as is. Now I'm regretting lowering my car with my back injury and all...
I don't think tokicos are soft.. They are madd stiff compared to konis or kybs where you can adjust the setting.. If you want better cornering and limited sway, considering you don't have it already, add an RSB & FSTB. Adding an RSB made a big difference for me..
Just my 2 cents!!!...
I have GC on my 00 se
I love them and I bought the ones that use the stock struts or can be upgraded to tokico. They have gc that are specifcally made for koni's too. My max is lowered as low as the coilover goes, but there is a metal bracket inside the wheel well that won't allow it to go lower in the fornt. But if that wasn't there i would be tucking wheels big time. Right now it there is no gap right on top of the tire and there is no rub and rides good.
Re: I have GC on my 00 se
If you really want gc, I suggest 400 to 450lb springs f&r, and agx struts so you can adjust it accodinly. You then have to have the body of the strut threded, some new mounts so forth and so on. Personally I say no, it's not a real coilover.
Re: Re: I have GC on my 00 se
Originally posted by srbarnes4ever
Can you tell me what spring rates you used front and rear? I bought the GCs for my daily driver Ford Escort along with tokico struts and I think the ride sucks. The struts are waaay underdamped for the spring force (300# front/200# rear) so I'm going with conventional Eibach pro-kits for now until I find a good, adjustable strut to handle the load.
WEll you are comparing a ford escort to a maxima. Ride is so much different even stock. Just call Ground control and they have two versions based on what you are going to do with your stock struts. I have the GC coilovers for 2000 Max se that can be used with tokico or stock struts. Like i said i lowered it all the way and it ride is awesome. I had a 2000 civic with arospeed coilovers and they sucked - it was bouncin and made crunching sounds. But I would highly suggest GC for 5th gen maximas even with stock struts they are great.
yes
what do you mean by there are two different versions???
does gc have two different versons of the coilover for the maxima??
Re: yes
u can either get gc coilovers for stock/or tokico upgrade -- or u can get the ones for koni strut upgrade
my gc are pretty good even with the stock struts. but the rear rattles. and when i turn the steering wheel all the way to the right, the gc squeaks a bit, but otherwise regular turning and driving it dont squeak at all. just annoyed with the rattling. barely can tell though.
Re: Re: sooo
Originally posted by yo_its_ok
When you order, be sure to mention what shock combo you would like to get...its all about the red perch that has different Inside Diameters, and its honestly not that great of difference.
As for question about Cattman Coilovers, are nothing like the GCs.
CCs are a fully developed system.(somewhat) Incorporate adjustable height, and camber control via a upper camber plate.
GCs retain height adjustability, but that's it, the shocks are up to you, as well as opting for a camber plate or bolt.
When you compare any true Coilover set vs a coilover kit. There is no comparison.
Re: Re: Re: sooo
Originally posted by jhans114
I agree that the Cattman is a full coilover system but my question was does it squeek or rattle and how is the ride. I dont mind spending the extra money to get the CC but if the make the same noises and they also rattle then Ill go with GC. Thanks
Re: Re: yes
To those who have GC... Do hear squeqing? How rough is the ride? I need this info in facts cause I was about to get the H&R set up with Tokico but if the GC w/ the Koni set up is drivable then thats what Im gonna get. OR also how about the Cattman Coilovers? Are they better quality than the GC? Thanks
Non-squeaky setup???
So,
It seems alot of ppl have pleasing performance setups + squeaks. Is there anyone with a setup that is just firmer/better than stock and no squeaks? Or has anyone found a long term cure for the squeaks?
Re: Re: Non-squeaky setup???
Eibachs, KYB AGXs, custom upper strut mounts, FSTB, RSB, and RSTB.
AWESOME~~!
AWESOME~~!
Is it the custom upper strut mounts, that eliminates the squeaks?
Cause I think I've seen someone on here mention they have the Eibach and KYB AGX's setup and it squeaks.
If so, how much work/dollars are we talking for the custom strut mount work and like you said earlier how hard is this to maintain if something goes wrong?
pfsssh
woosh!
Re: Re: sooo
Re: Re: Re: Re: Re: sooo
Jayson, Confused used some rubber gaskets and we put them on the top hat and on the perch, once in a while hear a squeak, but the metal banging has stopped, unless it was on the lift and we bring it back down and the springs don't settle right away.
I remember the first time I lowered the car off the lift and it made a loud banging noise, I thought I broke something, and Confused was laughing cause my face turned pale white, and he said the springs just settled in....
Re: Re: Re: Re: Re: Re: Re: sooo
LoL...it was a rubber sheet, and made it fairly tight, it eventually wears out and falls off. Trying to make some polyurethane coil covers, so it wil reduce the clanging sound.
I know GC used to have Polyurethane upper cushions before, I don't remember if they still offer it, but doesn't hurt to ask.
Rubber quieted things for a whole day, the next day the sounds were back.
one day is a little shocking. I contacted severel companys about some poly joints but got blown off, so who knows, but i din't ask gc. I looked at the rears today on the lift, and noticed (now I havn't seen the car in months) but noticed an odd amount of paint coming off of the uper mount. Now of course there gonna chip a little where the spring sits, but to me it looked like it was bouncing around the mount a little. So maybe having a recessed section where the spring could "lock" into might help. Maybe that should be the upgrade Brian should look into for gen3.
MAXIMA_STYLE
112
Nov 5, 2013 01:00 PM
po8pimp
Sep 14, 2007 03:33 PM
evil_spork
Jun 9, 2006 08:45 PM
evil_spork
Jun 9, 2006 04:04 PM
