Difference in Bumper Lenses - Diamond cut, etc?
Pretty new here, but what's the difference between normal clear bumpers and the "diamond cut" clear bumper lenses, other than the additional $30.00 that procarparts.com is charging? I kind of like the normal because it will somewhat match the corner lenses and the fogs...
what are your thoughts, opinions...
Re: Difference in Bumper Lenses - Diamond cut, etc?
Top "Regular Clears"
bottom "Diamond Cut"
Diamonds are better to me!!!!!
These are the cloudy white plastic ones...https://maxima.org/shoptalk/sub_modi...rs/index.shtml
IMHO the diamond cut ones look better. I had the cloudy version on my car first and then sold them and bought the diamond cut ones. They look a thousand times better as they match the headlights and fogs better.
Re: Re: Difference in Bumper Lenses - Diamond cut, etc?
Originally posted by ljl10
These are the diamond cut ones...http://www.custommaxima.com/DiamondCutBumperLights.html
i went back to regular clears due to water leakage on my diamond cuts.
Ant
Re: Re: Re: Difference in Bumper Lenses - Diamond cut, etc?
Originally posted by ny96max
Hey!! thats my max on CustomMAx with the diamond cuts and the infamous SMX grille...
Ant
Ant
Ant
Ant
oh yeah.. diamonds are also the most likely to get stolen.. u'll start to have to park nose in.. i'm on my second set.. but don't worry u'r probably not as paranoid as me..
You don't have to worry about this with the new ones...
Just buy some clear silicone and seal those babies up...actually helps snug them in the bumper recess better.
Oh yeah and another vote for the Diamond-Cuts.
-Cyrus
i'm all for the diamond cut. there is a big difference between the two. if you looked at the pictures above you can see that looking through the diamond cuts is like looking through a window. as for the regular clears, it's like looking through a foggy window.
Re: You don't have to worry about this with the new ones...
Originally posted by Vyrus
The newest shipment of CustomMaxima.com and Stealth Max corners are leak-proof. The leaks only occured with the older Diamond-Cut versions.
-Cyrus
-Cyrus
Re: Re: You don't have to worry about this with the new ones...
Originally posted by Victim64
Haven't seen any updates... does he actually have the REAL DC clears in??
-Cyrus
Re: Re: Re: You don't have to worry about this with the new ones...
The reason for the huge wait for them was because he was getting a whole new batch of water-proof ones. What do you mean by "REAL" clears?
-Cyrus
-Cyrus
Re: Re: Re: Re: You don't have to worry about this with the new ones...
UMMM Nope, the ones that were being made water proof were not REAL DC clears, they were regular ones... Are we talking about the order of 1,000 lights that he was waiting on because they were fixing the housing?? If so, then those were not DC clears... they were all regular old clears and that is how he sent them out and it was a big old mess. I odered DC clears and got regular clears along with everyone else on the long back order list. Didn't you know about that??
), and no leaking.
-Cyrus
Re: Re: Re: Re: Re: You don't have to worry about this with the new ones...
I thought only a few people got the non-DC cut and that was a shipping error? Oh well I bought from Stealth Max and mine don't leak for sure... I just sprayed each one for 2 minutes with a hose (since I was already washing the car and wanted to test them
), and no leaking.
-Cyrus
), and no leaking.
-Cyrus
Re: Re: Re: Re: Re: Re: You don't have to worry about this with the new ones...
You got lucky then, cause if the numbers Greg gave were right, then he sent out 600 plus regular clears as DC clears??
-Cyrus
I bought my first set in feb of '01.. and i'm pretty sure thats when they just came out.. cause as far as i knew Procarparts where the only ones sellin them.. and they didn't ever leak..
Originally posted by Chron!cRAGE:
Does anyone know if the clear corners from autodynamic.com are the same as the diamond cut ones from custommaxima.com? They look the same but are they the older version that leak?
James92SE
142
Jan 2, 2024 09:23 AM
The Frye
Sep 2, 2021 11:03 AM
t6378tp
Sep 29, 2018 04:27 PM
