Breather Valve Question
Hey, I bought the breather valve from Discount auto parts. It goes on easy, but I don't know what to do with the other side of the hose that goes to my Place Racing CAI, what did you all do?
I have a question to add - I've had a breather element for about 3,000 miles now and wonder if it could be the cause of a whistling noise I occasionally get. The noise is RPM related and I can't trace it back to any one component. It's only audible like once a week so it's not a big concern and it's hard to diagnose but I'm wondering if other people w/ breather valves experience this??? The breather valve is the only thing I've done recently so I question if that's the culprit. Otherwise I'm afraid it may be my alternator or P.S. pump starting to whine. Thanks.
Originally posted by Tai Mai Shu
Plug it with what? not a bolt!
-Cyrus
Ravq, I will test my theory. IT is so intermitent though. I've also recently replaced the PCV valve so the system should be working properly???
Thanks for the response Vyrus. I'll post if I am able to determine if my whine is from that.
Re: Re: Breather Valve Question
Originally posted by I30CeFiRo
Does the breather give any sort of gains or is it just for looks??
http://forums.maxima.org/showthread....5&pagenumber=2
Hope this helps. ALso, from some of threads I found w/ a search, some others report a slight whistling sound.
Max139617
Sep 20, 2015 07:09 PM
