Maxspeed Springs Installed
Old Mar 17, 2002 | 08:45 PM
theMax's Avatar
Maxspeed springs installed on a 2001 SE (auto) "theMax" and GXE (manual) "Zeitgeist57"
Install took 6 hours for both cars with no breaks. (unless we count the FSTB bolts we broke trying to remove
There were minor differences between the two cars. Bumpstops on the SE were foam inside the rubber dustboot, on the GXE they were part of the rubber dustboot. Bumpstops were not cut. Both cars are running on stock struts. If bottoming out occurs the bumpstops will be cut when new struts installed. Also there was an extra clip on the SE's front brake lines that make the strut a pain to remove. (very tight against the CV boot)
The Good:
Ride is much like stock, hard to tell a difference. Over big bumps it is a little stiffer and on turns...its great!
After the install I drove 70 miles home and found myself (SE) driving 10MPH faster than normal. Very good control at high speeds.
The Bad:
We both have some squeaking/rattling. I'm not sure if its the rubber around the bottom of the stock springs we reused or something else. More on that once we find the problem.
and The Ugly:
The springs are still yellow
Overall The springs are a good buy, you can't go wrong for $85!
Old Mar 17, 2002 | 09:05 PM
NuJerseyDrive's Avatar
Sweet breakdown, thanks. I'm trying to decide between the Maxspeed's or H&R's. We'll see.
Old Mar 17, 2002 | 10:28 PM
BigDogJonx's Avatar
Yellow is good for spring color
I love the ride and everything seems fine to me, no rattling or anything.
Dixit
Old Mar 18, 2002 | 04:43 AM
zeitgeist57's Avatar
Yeah...we had a blast! Eddie and I do agree...despite whatever is making the squeaking/rattling sound, the improved handling and stance is well worth the money and time.
If we've got you interested in Maxspeed springs, check out the "Group Deals" section for a 3rd round GD!
Bottom line? Great ride, great handling...very pleased with Maxspeed!
Old Mar 18, 2002 | 04:52 AM
craaaazzy's Avatar
i'm having the same problem w/ the rattlin, no sqeaking for me though. i thought i was the only one, i was going to take everything apart and retighten it. let me know if u guys find the solution.
Old Mar 18, 2002 | 05:00 AM
Well...if YOU'RE going to take yours apart, maybe we'll wait to hear from YOU I know for a fact, from contorting my body in such a way that I could feel the rear strut tower AND still push down on the rear of the car, that my noise is from the strut stem bolt rubbing against the rubber top hat...but no matter how hard I tighten it, I can't seem to get it to stop! I'll rip everything apart in a month or two if I can't get it to quiet down before long.
Old Mar 18, 2002 | 05:41 AM
craaaazzy's Avatar
yep, already tighten the back myself w/ no luck. need to do the front but have to take it off in order to do that. hopefully, we can check it out this weekend. any ideas on what else i can check or do? grrrrr...
Old Mar 18, 2002 | 06:25 AM
PhantonR's Avatar
Dont make me lie, but...
I paid a local speed shop $125 to put these on for me. I did watch him do the whole thing, accept for how to pull the back carpet out. My ride is noticablly stiffer and I have an SE. I also noticed alot of bounce, but that has smoothed out nicely. To be honest is was definitly easier to pay someone to put the springs on verses me tryin to do it by myself. If I learned anything, it is that I need more tools. As for handling, Lets just say that I cant find enough curvy roads.
Old Mar 18, 2002 | 06:36 AM
Tony Fernandes's Avatar
Re: Maxspeed Springs Installed
Originally posted by theMax
The Bad:
I had some rattles/squeaks as well until I got an alignment. I know very little about alignments and such, but everything seemed tighter and quieter once I had it aligned.
Tony
Old Mar 18, 2002 | 07:21 AM
timby01's Avatar
Re: Re: Maxspeed Springs Installed
do they make these springs for a 02 and also how much is the drop?
Old Mar 18, 2002 | 08:41 PM
theMax's Avatar
PICS
http://www.angelfire.com/nj/psychohome/maxspeed.html
Pics of the install...
Warning, slow loading...
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
