What is a good Koni adjustment?
I just installed a set of Koni's on my maxima. (kind of a pain but...hopefull worth it) I have Intrax springs (1 3/4) and am wondering what setting is good for this set up? Right now i adjusted the rear to full soft and the front to a half turn to firm (?) soft/med. It rides nice. almost like stock. Is this ok?
basically...Are the shocks going to be ok at this setting?
Re: What is a good Koni adjustment?
Re: Re: What is a good Koni adjustment?
Most people seem to set their rear shocks (Koni or AGX) around 75% to minimize the infamous bounce of the light back end. I've had mine set there a long time, though right now I could see going down to 50%. I assume you got Konis for better performance, so you'll want to stiffen the rear to compensate for FWD understeer. Check http://www.rogerkrausracing.com/ , read the "Understeer/Oversteer Correction Sheet". Fronts I used to run full soft on the street, full firm for autocrossing, but I actually think it's more comfortable about 50% in front for daily use. Of course, springs affect this, and I'm on coilovers. Remember, the springs to the support work, struts/shocks just dampen the spring rate.
Re: Re: Re: What is a good Koni adjustment?
I got my rears 75% stiff 2 full turns and the fronts full stiff and so does Cumalot he says he loves the way the cars handles, I also have intrax springs as well. No potholes I go full stiff, but hopefully Ill be living in Atlanta and I am going full stiff all the way.
Re: Re: Re: Re: What is a good Koni adjustment?
Jaime, don't you remember what's my rear Konis are set at? Is it the same as yours...75%?
Re: Re: Re: Re: Re: What is a good Koni adjustment?
What roads do you guys have that you can put your Koni's so stiff!!?!! I have mine (with H&R no less) on full soft rear, 3/4 turn front. Seems to float much less than stock but is also harsher too. Much stiffer and the ride becomes punishing... It's not like I can't take it, but I feel bad for the car as it is obviously taking jarring blows/rattles and that can't be good. On smooth roads and highways it is pure joy but the fact remains that in my immediate neighborhood, the good roads are a rare commodity.
Re: Re: Re: Re: Re: Re: What is a good Koni adjustment?
But the point is....IS THIS OK FOR THE KONI'S? or....will this harm the shocks. (riding full soft rear)??
Re: Re: Re: Re: Re: Re: Re: What is a good Koni adjustment?
I agree... I set the rears to 75-90% firm the first day i put them on and it was literaly like driving around in a box cart. No suspension! The car hoped on the highway, and you got tossed around inside the car. I understand performence...but its a maxima not an F1 car. With the rears set to full soft and fronts a half turn the car rides smooth but still handles better then stock shocks.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
