Throttle positioning sensor?
Old Apr 14, 2002 | 08:43 PM
Joseph77's Avatar
Do maximas have a throttle positioning sensor? The reason I ask is the other day while in traffic I would step on the accelerator just barely and the rpm's would go up to about 1500 and then dip back down to below 500 and act like it was going to die. I immediately checked the throttle cable to see if it was loose and sure enough it was, so I tightened it just a little and the problem pretty much went away. Except it is still kind of sluggish like while applying slight throttle pressure. Ie; the car reves but seems like something is slipping in the tranny or maybe the throttle positioning sensor. This only happens occasionally, but it is pretty annoying, and I would like to have instantaneous acceleration like I get for the majority of the time. Has any one else experienced this with there automatic Maxima? Thanx for the comments.
Old Apr 14, 2002 | 09:40 PM
NmexMAX's Avatar
dot dot dot ...
Yeah, Maxima has a throttle position snesor, or "TPS" as refered to on this board. Goes for around 70 dollars from the dealer. It's the weird looking thing next to the throttle body, has two electrical connectors plugged into it.
Old Apr 14, 2002 | 09:51 PM
Joseph77's Avatar
How can I check the TPS to see if it is still ok? I have a voltmeter. Thanx
Old Apr 14, 2002 | 09:54 PM
NmexMAX's Avatar
dot dot dot ...
I know there is a way, but I dont not know the link off hand, do a little searching here and online, and maybe @ maximadriver.com
Old Apr 14, 2002 | 10:08 PM
eaglclon's Avatar
here's the link
http://www.vbxmaxima.8m.com/tps.html
Old Apr 14, 2002 | 11:46 PM
97ABMAX's Avatar
The throttle position sensor is NOT $70, its like $250. I had to change mine a few months ago. Take Care
Old Jul 6, 2002 | 08:06 PM
MacGyver's Avatar
$250??? is that OEM from a local dealer? how much is an aftermarket? My tps just went. I remember when i needed hood struts and the dealer was like $90 for 1 and i got them aftermarket (fit perfectly) for $15 for 1
Old Jul 6, 2002 | 08:25 PM
Mad Jap's Avatar
I replaced mine about a year ago....
I bought the TPS from Courtesy Nissan for about $50.
mvm062
Nov 30, 2020 09:00 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
