My back passenger floor is soaked..
The floor on the back pasenger side of my car is completely soaked, it looks like someone took a hose and left it running in there for a few minutes.. Anyone know what the problem might be?
I'll guess the rear window is leaking. Check the trunk for signs of water. Other than that wait until it drys and try hoseing down a window at a time. Also check the door seals and sunroof (if you have one).
If you have a sunroof the drains might be clogged. There should be 4 of them. One in each corner. You can see them when the sunroof is open. there are tubes that run down the a and c pillars to drain the water at each corner of the car. You can pour water in them to make sure there draininmg properly.
check wheelwell
The water could be coming from below if you have a rusted or damaged area at the rear wheelwell. When you drive through standing water, the tires spray the water against the wheelwell. A very small hole will allow a lot of water to get in when you are driving in the rain. Good luck finding the source of the water and let us know when you figure it out.
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
erniel
Aug 8, 2015 09:32 AM
