Redline Transmission Fluid (ARrrrrgggggggggg)
O.K.
I replaced my transmission fluid with Redline MT-90. The instructions on www.greghome.com were very easy to follow, Thanks. I have had the fluid in for about 2 1/2 weeks. At first, everthing was smooth(no notches between gears),it was great. It even allowed me to get the car into first while still rolling. Recently(the past two days), I have noticed that the transmission is going back to its old ways, the notches have returned, I can no longer put it into 1st while rolling. It almost seems as if it has gotten worse, sometimes I really have to tug on the the stick to get it into 2nd and 4th.
Has anyone else had this problem?
What is causing it?
BTW I have a 2k2 6spd
What is causing it?
Re: Redline Transmission Fluid (ARrrrrgggggggggg)
Originally posted by Bulldawg
O.K.
What is causing it?
O.K.
What is causing it?
O.K.
What is causing it?
O.K.
What is causing it?
Sep
Did you do what colonel suggested?
I haven't done it yet just curious if you did, and if so what you found?
amount dribbled out, so I know it is full.
I'm not sure about your tranny though, I think the 2002 6-speed takes right at 3 quarts?
He is right, the fluid should be right under the fill hole.
Hope that helps.
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
